Discuss
Ice maker works. Won't dispense cubes or crushed ice
 in
Refrigerator & Freezer Repair
I was wondering if you could help me solve my latest problem with my Frigidaire MRS26LGJ? The ice maker works.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice maker works. Won't dispense cubes or crushed ice
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-10-2008, 07:07 PM
Derjimmer Derjimmer is offline
Junior Member
Derjimmer is on a distinguished road
Thumbs down Ice maker works. Won't dispense cubes or crushed ice
Model Number: MRS26LGJ   Brand: Frigidaire   Age: 5 - 10 years
The ice maker works. But I can't get it to dispense ice cubes or crushed ice. When pushing the button to get either, the mechanism makes a noise, but nothing comes out. I open the freezer door, and open the ice bin door, and the ice is pushed from the back of the bin to the front of the bin. So I know the auger is working. It's like a trap door is not opening to let the ice out. I removed the bin, and cleaned it. I did notice rust on the metal parts at the front of the bin. While the bin was removed, I manually checked the parts at the rear of the freezer to see if they were working. The drive spun, and the little door to the right of the drive, opened and closed (with a loud click), depending on whether I wanted crushed or cubed ice. Any suggestions?
Thanks.
Jim Hayden
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-11-2008, 02:17 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Jim,
Did the ice door in the dispenser open when you pushed the lever?
Did the ice cubes stuck in the ice chute on the freezer door?
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 04-12-2008, 06:06 AM
Junior Member
Default
If you are talking about the little trap door in the ice chute, the answer is no. Ice doesn't make it to the chute to get stuck.
  #4 (permalink)
Old 04-12-2008, 10:34 PM
DSEABOLT DSEABOLT is offline
Junior Member
DSEABOLT is on a distinguished road
Default Frigidaire MRS26LGJW0 same problem this week
The drive blade which drives the ice dispenser is stripped out and lets the auger spin with out moving ice forward. To replace part you have to remove auger just remember the order the crushing blades came off.
You may have to replace auger if worn.
Go to www.appliancepartspros.com
select diagram #4 ice container part #17
Drive blade
Part Number: AP3959143 made by FRIGIDAIRE about $15
Good Luck
  #5 (permalink)
Old 04-15-2008, 08:56 AM
Junior Member
Default
The ice does move forward to the front of the ice bin, but doesn't come out. It's as if the ice is not dropping into the crushing part of the mechanism, ar getting past that part. Does this still mean that the driver blade which drives the ice dispenser is still stripped?
  #6 (permalink)
Old 04-15-2008, 09:45 PM
Junior Member
Default
yes, see if you can rotate the drive blade while you hold the auger still if so the drive blade is stripped.
  #7 (permalink)
Old 04-22-2008, 04:50 PM
Junior Member
Default
Quote:
Thanks. That was the problem. Because the metal plate at the inside front of the ice bin was rusted, I decided to replace the entire bin. It arrived, I installed, and it now dispenses and crushes ice beautifully. Thanks for your input.
  #8 (permalink)
Old 06-27-2008, 06:31 PM
vantrice vantrice is offline
Junior Member
vantrice is on a distinguished road
Default I'm having a problem with my MRS26LGJ too...
I just want to replace the entire bin! Rust is coming from somewhere and it dispenses out with the ice! It's a pain!
I've had this refrigerator for about 6 or 7 years now.
Where did you get yours so I can purchase one too?
I would REALLY appreciate it
  #9 (permalink)
Old 06-27-2008, 06:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
vantrice,
What is the model number of the refrigerator?
__________________
  #10 (permalink)
Old 06-29-2008, 07:45 AM
Junior Member
Default
Frigidaire MRS26LGJ
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE ice maker crushes, no cubes nainex9 Refrigerator & Freezer Repair 3 09-15-2008 07:32 PM
ice maker crushes, no cubes sfshipley Refrigerator & Freezer Repair 7 03-12-2008 03:04 PM
Ice maker will not dispense Jackson Refrigerator & Freezer Repair 1 02-08-2008 02:53 PM
Water Won't Dispense Ice Maker Works PAULUS1024 Refrigerator & Freezer Repair 5 11-26-2007 06:21 PM
Ice maker motor doesn't push out cubes to bin dpnmars Refrigerator & Freezer Repair 0 10-30-2007 09:31 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
