Discuss
Wont Defrost And Fridge Not Cool
 in
Refrigerator & Freezer Repair
HI, We have a GE TFH 27 PR side by side fridge/freezer that will not defrost, the freezer coils
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Wont Defrost And Fridge Not Cool
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-10-2008, 02:35 PM
RDWEDEL RDWEDEL is offline
Junior Member
RDWEDEL is on a distinguished road
Question Wont Defrost And Fridge Not Cool
Model Number: TFH 27 PR   Brand: GE   Age: More than 10 years
HI, We have a GE TFH 27 PR side by side fridge/freezer that will not defrost, the freezer coils freeze up solid so there is no air flow to the fridge compartment from the freezer. In the fridge side behind the plastic cover for the controls is a motor that i assume is some sort of a timer, it seems to be working and when i turrn it manually it shuts off the compressor. Any help would be great! - Russ.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-10-2008, 06:43 PM
gearhead1218 gearhead1218 is offline
Member
gearhead1218 is on a distinguished road
Default
You obviously have a defrost issue.
The control you refer to is the defrost timer.
The GE's are noted for heater element failures. After FULLY defrosting the freezer, you will need to pull the panel off the back wall of the freezer to expose the evap coil. There you will find the heater assembly. With the unit unplugged, remove a wire from at least one side of the heater (or heaters) and check for continuity. If you have an open cicuit, then the heater is bad. The replacement heaters on GE's usually also include a new defrost limit switch, replace it as well.
If you have continuity on the heaters and the defrost limit control, the replace the timer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator Wont Cool cottonslurpy Refrigerator & Freezer Repair 1 01-29-2008 02:38 PM
Freezer is cold, fridge is cool at best sroney Refrigerator & Freezer Repair 0 12-30-2007 08:50 PM
freezer cool/fridge warm grose70 Refrigerator & Freezer Repair 2 11-05-2007 06:07 PM
freezer temp is ok, fridge won't cool frigidaire Refrigerator & Freezer Repair 0 10-08-2007 03:55 AM
Freezer works, Fridge won't Cool...fan stops Gamla33 Refrigerator & Freezer Repair 1 10-07-2007 12:15 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
