| » Force defrost on board GE Fridge? |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
As far as I know there is no way to do it.
What is the original problem with your fridge? Gene.
__________________
Professional appliance repair services in Orange County, California. |
You can check the defrost heater and the defrost thermostat for continuity. Both of them should be closed (the defrost thermostat must be cold at the test time).
__________________
You can manually force defrost. Remove the back metal panel to expose the motherboard and unplug the power plug on the bottom left. Stick a jumper between the J11 and J 8 connector pins. The pc board will have these pins labeled. Now plug in fridg. The defrost heater will now draw current, if yes, you probably have a bad motherboard item # 801. They also recommend to also replace the freezer thermister. If not, you have a bad defrost heater or thermostat. Very common for the heater to fail on these.
__________________
- Last edited by richappy : 04-11-2008 at 04:17 AM. |
| Display Modes | |
| defrost heater | Kenny Duke | Refrigerator & Freezer Repair | 1 | 03-19-2008 01:10 PM |
| Defrost Timer AGAIN | Karen S | Refrigerator & Freezer Repair | 5 | 01-05-2008 06:12 AM |
| Kitchen Aid Fridge KSCS25FKSS00 is freezing on the fridge size | shawnharper | Refrigerator & Freezer Repair | 0 | 09-03-2007 10:27 PM |
| Kenmore fridge - water drips into fridge | njblue55 | Refrigerator & Freezer Repair | 3 | 08-07-2007 07:50 PM |
