Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   Force defrost on board GE Fridge? (http://forum.appliancepartspros.com/refrigerator-freezer-repair/7105-force-defrost-board-ge-fridge.html)
mmalone2 04-09-2008 06:02 PM
How do you force a manual defrost on a fridge with a control board. I have a GE GSS22JFMC side by side. No owners manual.
Gene 04-10-2008 01:31 PM
As far as I know there is no way to do it.
What is the original problem with your fridge?
mmalone2 04-10-2008 07:11 PM
The original problem was the coil in the freezer iced up. I wanted to put it in to defrost so I could check the heater and the defrost thermostat.
Gene 04-10-2008 09:01 PM
You can check the defrost heater and the defrost thermostat for continuity. Both of them should be closed (the defrost thermostat must be cold at the test time).
richappy 04-11-2008 02:27 AM
You can manually force defrost. Remove the back metal panel to expose the motherboard and unplug the power plug on the bottom left. Stick a jumper between the J11 and J 8 connector pins. The pc board will have these pins labeled. Now plug in fridg. The defrost heater will now draw current, if yes, you probably have a bad motherboard item # 801. They also recommend to also replace the freezer thermister. If not, you have a bad defrost heater or thermostat. Very common for the heater to fail on these.
