Discuss
Overload
 in
Refrigerator & Freezer Repair
I have just purchased and received a overload switch (4344040). The new part is slightly different to the old part.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Overload
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-08-2008, 05:02 PM
iainbelcher iainbelcher is offline
Junior Member
iainbelcher is on a distinguished road
Default Overload
Model Number: TR21V2W   Brand: Amana   Age: 5 - 10 years
I have just purchased and received a overload switch (4344040). The new part is slightly different to the old part. The old part had 2 full length brass spade connectors. One is for the overload switch and one connects to the condenser fan motor. On the new overload one of the spade connectors has been trimmed short. I can still connect to the spade connector but the connection is not as secure as it would be with a full length connector. See attached photo.
Will I be OK to use the overload as is ?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-09-2008, 04:00 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Check my article in the general talk section (replacing compressor start devices). Your overload is a critical part and saves the compressor from failure from hard start conditions. Using a substitute part will not give you the original protection and will void your warranty.
Your overload trips out at some very specific temperature or current. If you can get the supplier to PROOVE this one has the SAME specs as the old one, then maybe you can use it, but it will void your warranty and be harder to wire in.
__________________
  #3 (permalink)
Old 04-09-2008, 04:47 AM
Junior Member
Default
richappy,
Your reply does not really answer my question. The overload I purchased was the approved part on the appliance parts pro website. It looks exactly like the original except for the difference in the spade connector. Can it be used with a short spade connector ?
  #4 (permalink)
Old 04-10-2008, 01:10 AM
Senior Expert
APP Volunteer
Default
IF you have to change the fridg's wiring to use the part, it will void your compressor warranty.
__________________
  #5 (permalink)
Old 04-10-2008, 06:12 PM
Junior Member
Default
richappy,
You are missing the point of my question. I am not concerned about a warranty, the fridge is over 7 years old.
All I am trying to do is to get the fridge & freezer working again so I can get a little more life out of the appliance before I scrap it.
Now the question is "will the short spade connector on the overload allow it to function properly ?" If you don't know the answer to the question please pass it on to someone who does.
Thanks,
  #6 (permalink)
Old 04-10-2008, 06:26 PM
gearhead1218 gearhead1218 is offline
Member
gearhead1218 is on a distinguished road
Default
That short stub shouldn't make a difference.
The two old spades were actually tied in together.
Pick up a spade connector with a flag on it to be able use the single connection for both wires.
But, a point to ponder. Why did the old overload fail? If it was due to a high amount of heat on the compressor, then the compressor could be on it's way out. If the overload connection on the compressor was loose, then you may be alright, as the loose connection would have caused resistance and therefore heat.
Good luck.
  #7 (permalink)
Old 04-11-2008, 06:35 AM
Junior Member
Default
gearhead1218,
Thanks for the reply. I've now connected to the short stub and it seems to be working fine.
The overload failed because the plastic housing had cracked and then when I tried to disconnect the leads from it, it fell apart. It has obviously got really hot at some point.
Now it's all working again I'll keep an eye on it.
Thanks for answering my question.
  #8 (permalink)
Old 04-11-2008, 01:45 PM
Admin / APP Team Admin / APP Team is online now
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Just to clarify, the overload you ordered from us (Whirlpool 4344040) is the right and direct replacement. The reason why it is slightly different is because Amana has changed ownership twice in the recent years. First it was bought out by Maytag, then Maytag was bought out by Whirlpool. In the process, both Maytag and Whirlpool were/are trying to adapt similar (often exact) parts they already manufacture to work on these brands that they have purchased. Using these parts will not void product warranty, because they are in fact original replacement parts.
Glad to hear the fridge is back in working order.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
AMANA overload relay replacement cc703 Refrigerator & Freezer Repair 2 04-24-2008 07:14 AM
Relay Overload, Start Capacitor Combo Install rmam Refrigerator & Freezer Repair 0 12-01-2007 09:37 AM
No spin cycle after towel overload iwash Washer Repair 2 10-02-2007 03:01 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
