| » Frigidaire Side by Side |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: FRS24ZSGB0 Brand: Frigidaire Age: 5 - 10 years
I have a Frigidaire side by side. Over this past weekend I had to get into the freezer to unfreeze the drain plug. After I have put it all back together, now the front panel will not work. I get no ice, water, or light. The ice maker is still making ice though so I suspect it may be electrical. Any suggestions on where to start?
At the bottom of the freezer door going thru the hinge is the wiring harness for the dispenser system. that harness should plug into another harness right there in the same area. Check that plug. Either that or you have a broken wire which if it's in the door would mean a new door, since the harness is molded into the door.
Hi FixingIt,
The first thing I would check is the dispenser switch (#125 on the controls break down diagram) on the freezer control panel. - The part number for the dispenser switch is AP2110937 Here are the break down diagrams for the Frigidaire refrigerator Model FRS24ZSGB0 Gene.
__________________
Professional appliance repair services in Orange County, California. |
I'm glad you were able to fix it.
__________________
| Display Modes | |
| side by side refrigerator stopped cooling and freezing | bbcowboy | Refrigerator & Freezer Repair | 3 | 03-21-2008 06:02 PM |
| GE side-by-side water dispenser tube install | rumali | Refrigerator & Freezer Repair | 0 | 02-09-2008 05:54 PM |
| amana SDC25TL side by side coil frozen..why? | weel | Refrigerator & Freezer Repair | 3 | 11-19-2007 08:14 PM |
| Frigidaire side-by-side ice maker | bittersweet | Refrigerator & Freezer Repair | 0 | 08-12-2007 11:27 AM |
| Amana Side by Side Refrigerator Freezer MFG. P1317202WE | josephbowles@earthlink.ne | Refrigerator & Freezer Repair | 0 | 08-10-2007 05:38 PM |
