Freezer problem
3. 4/6-It is over one week after I defrosted refrigerator. Working good, when I opened back freezer panel all coils covered with ice. It not shows through the wall, like when the last time when temp dropped. Does anyone know if coils in the freezer should cover with ice????
2. 3/29 - Just finished cleaning ice and turned back on. Refrigerator is very quite no fan or other noises. Power is on. May be it needs some time before computer? re-boot? Do I need to put back inside wall in the freezer which covered coils? What else do I need check?
1. I have GE Refrigerator, side by side. GSS22KGPAWW S/N 210022. Unit starts warm up. Back wall inside Freezer is covered with ice. Two week ago its happen, I turned off and turned back on after one day and it worked for just for two weeks. Last time I opened panel from the back and vacuum cleaned. Now it’s happen again - warming and freezer covered with ice. I was looking for diagram under ref to start trouble shooting but nothing under ref. Do you have this diagram? And of cause, I am looking for help.
Thank you.
Mike
