Discuss
Compressor cycles on and off every few minutes
 in
Refrigerator & Freezer Repair
The compressor on my Kenmore 27 side-by-side refrigerator cycles on and off about every four minutes or so. The problem
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Compressor cycles on and off every few minutes
  #1 (permalink)
Old 01-16-2010, 05:04 PM
Junior Member
patrickmcglashan is on a distinguished road
Angry Compressor cycles on and off every few minutes
Model Number: 363.8597780   Brand: Kenmore   Age: 5 - 10 years
The compressor on my Kenmore 27 side-by-side refrigerator cycles on and off about every four minutes or so. The problem began right after the Sears technician installed a retrofit kit on the refrigerator. The problem started when the refrigerator defrosted itself or stopped working for about two days. Then all of a sudden it started working over the next several days as evidenced by ice in the ice maker, frozen liquids in the freezer and up until the Sears tech arrived. I called Sears and they sent someone over. The tech removed a panel in the back of the freezer and noticed that the evaporator coils were only 50% frosted over. He said that either the compressor is bad of the freon needs to be recharged. I asked him to recharge the freon since it was far less than replacing the compressor. He connected his recovery tank and recovered the R-12 freon. Unfortunately, he failed to realize that R-12 freon was no longer available. He had to install a retrofit kit to the refrigerator in order for the system to use the new R-134 freon. After the work was finished he turned on the refrigerator. He then felt the evaporator coil and noticed that it was getting cool. He told me that within the next twelve hours the refrigerator will be back to normal. A little less than an hour after he left the refrigerator stopped working completely. The only thing that was running was the fan inside the freezer. The compressor then began to cycle on and off every four minutes or so. I called Sears again but long story short, they refuse to do any more work on the refrigerator because, according to them, the refrigerator has a bad compressor. The last tech (tech 3 of 3) that came to look at the refrigerator refused to even check the pressure in the system to confirm whether or not the R-134 freon had leaked out due to a bad solder joint as a result of the work done to install the retrofit kit etc. I believe that if he had done so he could've said well, "since the freon charge is within limit/out of limits, then your compressor must be good/bad." I would have accepted that conclusion, however, the last two techs who came out just blew me off. I would appreciate any feedback or comments on my problem.
Thanks in advance,
Patrick
Related Models
Kenmore 3631401190 DISHWASHER
Kenmore 3631401191 DISHWASHER
Kenmore 3631401590 DISHWASHER
Kenmore 3631401591 DISHWASHER
Kenmore 3631401592 DISHWASHER
Kenmore 3631401890 DISHWASHER
Kenmore 3631401891 DISHWASHER
Kenmore 3631401892 DISHWASHER
Kenmore 3631402190 DISHWASHER
Kenmore 3631402191 KENMORE DISHWASHER
Kenmore 3631402192 DISHWASHER
Kenmore 3631402590 DISHWASHER
Kenmore 3631402591 DISHWASHER
Kenmore 3631402592 DISHWASHER
Kenmore 3631402890 DISHWASHER
Kenmore 3631402891 KENMORE DISHWASHER
Kenmore 3631402892 DISHWASHER
Kenmore 36314031000 DISHWASHER
Kenmore 36314031001 DISHWASHER
Kenmore 36314032000 DISHWASHER
Kenmore 36314032001 DISHWASHER
Kenmore 36314038000 DISHWASHER
Kenmore 36314038001 DISHWASHER
Kenmore 36314039000 DISHWASHER
Kenmore 36314039001 DISHWASHER
Kenmore 3631404193 DISHWASHER
Kenmore 3631404194 DISHWASHER
Kenmore 3631404196 DISHWASHER
Kenmore 3631404197 DISHWASHER
Kenmore 3631404593 DISHWASHER
Kenmore 3631404594 DISHWASHER
Kenmore 3631404595 DISHWASHER
Kenmore 3631404596 DISHWASHER
Kenmore 3631404597 DISHWASHER
Kenmore 3631404893 DISHWASHER
Kenmore 3631404894 DISHWASHER
Kenmore 3631404895 DISHWASHER
Kenmore 3631404896 DISHWASHER
Kenmore 3631404897 DISHWASHER
Kenmore 36314051690 DISHWASHER
Kenmore 36314051691 DISHWASHER
Kenmore 36314061790 AUTOMATIC DISHWASHER
Kenmore 36314061791 DISHWASHER
Kenmore 36314071790 AUTOMATIC DISHWASHER
Kenmore 36314071791 DISHWASHER
Kenmore 36314071792 DISHWASHER
Kenmore 36314071793 DISHWASHER
Kenmore 36314071794 DISHWASHER
Kenmore 36314072790 AUTOMATIC DISHWASHER
Kenmore 36314072791 DISHWASHER
Kenmore 36314072792 DISHWASHER
Kenmore 36314072793 DISHWASHER
Kenmore 36314072794 DISHWASHER
Kenmore 36314072795 DISHWASHER
Kenmore 36314074790 AUTOMATIC DISHWASHER
Kenmore 36314074791 DISHWASHER
Kenmore 36314074792 DISHWASHER
Kenmore 36314074793 DISHWASHER
Kenmore 36314074794 DISHWASHER
Kenmore 36314075790 AUTOMATIC DISHWASHER
Kenmore 36314075791 DISHWASHER
Kenmore 36314075792 DISHWASHER
Kenmore 36314075793 DISHWASHER
Kenmore 36314075794 DISHWASHER
Kenmore 36314081990 DISHWASHER
General Electric 36314081991 DISHWASHER
Kenmore 36314081992 DISHWASHER
Kenmore 36314081993 DISHWASHER
Kenmore 36314081994 DISHWASHER
Kenmore 3631410690 DISHWASHER
Kenmore 3631410691 DISHWASHER
Kenmore 3631410692 DISHWASHER
Kenmore 3631410693 DISHWASHER
Kenmore 3631410694 DISHWASHER
Kenmore 3631411690 DISHWASHER
Kenmore 3631411691 KENMORE DISHWASHER
Kenmore 3631411692 DISHWASHER
Kenmore 36314141690 DISHWASHER
Kenmore 3631414593 DISHWASHER
Kenmore 3631414594 DISHWASHER
Kenmore 3631414595 DISHWASHER
Kenmore 3631414596 DISHWASHER
Kenmore 3631414597 DISHWASHER
Kenmore 3631414598 DISHWASHER
Kenmore 3631414691 DISHWASHER
Kenmore 36314151000 DISHWASHER
Kenmore 36314152000 DISHWASHER
Kenmore 36314158000 DISHWASHER
Kenmore 36314159000 DISHWASHER
Kenmore 36314171790 AUTOMATIC DISHWASHER
Kenmore 36314171791 DISHWASHER
Kenmore 36314171792 DISHWASHER
Kenmore 36314172790 AUTOMATIC DISHWASHER
Kenmore 36314172791 DISHWASHER
Kenmore 36314172792 DISHWASHER
Kenmore 36314174790 AUTOMATIC DISHWASHER
Kenmore 36314174791 DISHWASHER
Kenmore 36314175790 AUTOMATIC DISHWASHER
Kenmore 36314175791 DISHWASHER
Kenmore 36314181200 DISHWASHER
Kenmore 36314181202 DISHWASHER
Kenmore 36314191990 DISHWASHER
Kenmore 36314191991 DISHWASHER
Kenmore 36314191992 DISHWASHER
Kenmore 36314191993 DISHWASHER
Kenmore 36314192990 DISHWASHER
Kenmore 36314192991 DISHWASHER
Kenmore 36314192992 DISHWASHER
Kenmore 36314192993 DISHWASHER
Kenmore 36314194990 DISHWASHER
Kenmore 36314194991 DISHWASHER
Kenmore 36314194992 DISHWASHER
Kenmore 36314194993 DISHWASHER
Kenmore 36314195990 DISHWASHER
Kenmore 36314195991 DISHWASHER
Kenmore 36314195992 DISHWASHER
Kenmore 36314195993 DISHWASHER
Kenmore 36314231100 DISHWASHER
Kenmore 36314232100 DISHWASHER
Kenmore 36314234100 DISHWASHER
  #2 (permalink)
Old 01-17-2010, 02:49 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
I never heard of a retrofit kit to charge a refrigerator, he probably just added a line tap to allow a re-charge with refrigerant.
In the process, he may have introduced air in the system that now has contaminated the capillary tube and clogged it up.
I would get a different servicer to look at it.
__________________
  #3 (permalink)
Old 01-17-2010, 09:35 AM
Junior Member
Default
Thanks for your response. I looked at the repair work again and didn't see a new capillary tube, however, there's a copper gizmo that looks line a small cylinder about 3-3.5 inches long and about 3/4 inch in diameter. This unit has a cap installed on one end. I suppose it's a dust cap for a valve. He also installed a copper tube from the side of the compressor with the same arrangement as the copper cylinder. The second tech that looked at the refrigerator noted, "repair work incorrect," on the receipt he left behind. The third tech verbally said, "I would not have done the repair work like that." All three techs were from Sears. The impression I got from tech 2 and 3 is that they don't want to open a bucket of worms by attempting to undo what the first tech did. Question: Since the compressor OVERLOAD relay keeps cycling on and off, would replacing it make any difference? Thanks a lot. Patrick
UPDATE: 1/17/2010.
I was looking at a few post on this forum and found one that mentioned something about disconnecting the CAPACITOR and check to see if the refrigerator runs. I disconnected both wires to the capacitor (I made sure I didn't touch any of the terminals on the capacitor) and plugged the refrigerator back in the wall. The refrigerator began to run continuously and the freezer is already getting cold. Seems I have a bad Capacitor. Comments from anyone? Considering the importance of the capacitor to the motor, I will have to go source one ASAP.
  #4 (permalink)
Old 01-17-2010, 12:00 PM
Senior Expert
APP Volunteer
Default
That is a run capacitor usually 12 to 15 microfarad, necesary to phase shift the stator current to add running torqe. Your compressor will slow down and eventually fail without it.
__________________
  #5 (permalink)
Old 01-17-2010, 12:48 PM
Junior Member
Default
Thanks for your input. By the way, I removed the capacitor and it was totally discharged...totally dead. The fridge is still running and getting colder and colder. I'm going to go shut her down and crank he up after I replace the capacitor. Once again, thanks for all your help. This is an excellent forum for both nubies and experienced techs. You guys saved me just over $800! That's what Sears was going to charge me to replace the compressor...without even troubleshooting the system.
  #6 (permalink)
Old 01-17-2010, 01:57 PM
Member
John @ Fischers is on a distinguished road
Default
wow, cant believe he didn't even check that before he entered a sealed system. Now he has created another potential problem in the long run, by causing a freon leak....
800.00 ???? for a 175.00 compressor + some labor,,,wow again. Just make sure you get a run cap like rich said. Definitely need to be there. Glad you saved some bucks. good job.
  #7 (permalink)
Old 01-17-2010, 03:48 PM
Senior Expert
APP Volunteer
Default
Keep a thermometer in the freezer, back wall should be between zero and 5 degrees, fair check for purity of refrigeration, charge level and compressor condition. The problems with this might not be over.
__________________
  #8 (permalink)
Old 01-17-2010, 04:04 PM
Junior Member
Default
Richappy. I can do the thermometer part with no problem. However, are you recommending I have a tech come over and check out the rest of the system? I will never call Sears again. Their truck had, "A&E" on the side. Do these guys just have a contract with Sears to do their service/warranty work?? I wouldn't recommend them to a good friend.
Patrick.
  #9 (permalink)
Old 01-18-2010, 01:43 AM
Senior Expert
APP Volunteer
Default
If you can't get good temperatures in the freezer, you will need to get a tech. to check refrigeration.
As far as prices, it's about $400-$600 to change a compressor here.It is $200-$300 for the compressor, and the rest labor plus a new dryer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Wont advance cycles... Have to manually turn knob to advance cycles at 2 points nickf829 Washer Repair 1 12-20-2009 04:43 PM
freezer warm, clicking noise from compressor, compressor very hot sgtmajor58 Refrigerator & Freezer Repair 1 08-08-2009 06:57 PM
Compressor and Compressor Fan Not Working sdowns Refrigerator & Freezer Repair 0 05-02-2009 08:08 PM
Compressor cycles ronapo Refrigerator & Freezer Repair 1 09-01-2008 06:31 AM
frig and freezer warm,clicking noisefrom compressor,compressor very hot tdot Refrigerator & Freezer Repair 4 04-02-2008 08:35 AM
