Discuss
Whirpool fridge won't get cold in fridge/freezer. HELP!
 in
Refrigerator & Freezer Repair
My fidge will not getting cold in the freezer or refrigerator. How do you check it to see if it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirpool fridge won't get cold in fridge/freezer. HELP!
  #1 (permalink)
Old 01-16-2010, 09:29 AM
Junior Member
Cynthia McDaniel is on a distinguished road
Default Whirpool fridge won't get cold in fridge/freezer. HELP!
Model Number: ED25CQXHB01   Brand: Whirlpool   Age: 1 - 5 years
My fidge will not getting cold in the freezer or refrigerator. How do you check it to see if it needs freon. It's running but not making ice or getting cold.
Ads By Google
Related Models
Whirlpool ED25CQXHB01
Whirlpool ED25CQXHB02
Whirlpool ED25CQXHB03
Whirlpool ED25CQXHN00
Whirlpool ED25CQXHN01
Whirlpool ED25CQXHN02
Whirlpool ED25CQXHN03
Whirlpool ED25CQXHT00
Whirlpool ED25CQXHT01
Whirlpool ED25CQXHT02
Whirlpool ED25CQXHT03
Whirlpool ED25CQXHW00
Whirlpool ED25CQXHW01
Whirlpool ED25CQXHW02
Whirlpool ED25CQXHW03
Whirlpool ED25DQXAB00
Whirlpool ED25DQXAB01
Whirlpool ED25DQXAN00
Whirlpool ED25DQXAN01
Whirlpool ED25DQXAW00
Whirlpool ED25DQXAW01
Whirlpool ED25DQXBB00
Whirlpool ED25DQXBB01
Whirlpool ED25DQXBN00
Whirlpool ED25DQXBN01
Whirlpool ED25DQXBW00
Whirlpool ED25DQXBW01
Whirlpool ED25DQXDB00
Whirlpool ED25DQXDB01
Whirlpool ED25DQXDB02
Whirlpool ED25DQXDB04
Whirlpool ED25DQXDB05
Whirlpool ED25DQXDB06
Whirlpool ED25DQXDN00
Whirlpool ED25DQXDN01
Whirlpool ED25DQXDN02
Whirlpool ED25DQXDN04
Whirlpool ED25DQXDN05
Whirlpool ED25DQXDN06
Whirlpool ED25DQXDW00
Whirlpool ED25DQXDW01
Whirlpool ED25DQXDW02
Whirlpool ED25DQXDW04
Whirlpool ED25DQXDW05
Whirlpool ED25DQXDW06
Whirlpool ED25DQXVF00
Whirlpool ED25DQXVF01
Whirlpool ED25DQXVF02
Whirlpool ED25DQXVF03
Whirlpool ED25DQXVF04
Whirlpool ED25DQXVF05
Whirlpool ED25DQXVF06
Whirlpool ED25DQXVF07
Whirlpool ED25DQXVG00
Whirlpool ED25DQXVG01
Whirlpool ED25DQXVG02
Whirlpool ED25DQXVG03
Whirlpool ED25DQXVG04
Whirlpool ED25DQXVG05
Whirlpool ED25DQXVG06
Whirlpool ED25DQXVG07
Whirlpool ED25DQXVM00
Whirlpool ED25DQXVM01
Whirlpool ED25DQXVM02
Whirlpool ED25DQXVM03
Whirlpool ED25DQXVM04
Whirlpool ED25DQXVM05
Whirlpool ED25DQXVM06
Whirlpool ED25DQXVM07
Whirlpool ED25DQXVN00
Whirlpool ED25DQXVN01
Whirlpool ED25DQXVN02
Whirlpool ED25DQXVN03
Whirlpool ED25DQXVN04
Whirlpool ED25DQXVN05
Whirlpool ED25DQXVN06
Whirlpool ED25DQXVN07
Whirlpool ED25DQXVP00
Whirlpool ED25DQXVP01
Whirlpool ED25DQXVP02
Whirlpool ED25DQXVP03
Whirlpool ED25DQXVP04
Whirlpool ED25DQXVS00
Whirlpool ED25DQXVS01
Whirlpool ED25DQXVW00
Whirlpool ED25DQXVW01
Whirlpool ED25DQXVW02
Whirlpool ED25DQXVW03
Whirlpool ED25DQXVW04
Whirlpool ED25DQXVW05
Whirlpool ED25DQXVW06
Whirlpool ED25DQXVW07
Whirlpool ED25DQXWN00
Whirlpool ED25DQXWW00
Whirlpool ED25DQXXN00
Whirlpool ED25DQXYN00
Whirlpool ED25DQXYN01
Whirlpool ED25DQXYN02
Whirlpool ED25DQXYW00
Whirlpool ED25DQXYW01
Whirlpool ED25DSXDB00
Whirlpool ED25DSXDB01
Whirlpool ED25DSXDB03
Whirlpool ED25DSXDB05
Whirlpool ED25DSXDN00
Whirlpool ED25DSXDN01
Whirlpool ED25DSXDN03
Whirlpool ED25DSXDN05
Whirlpool ED25DSXDW00
Whirlpool ED25DSXDW01
Whirlpool ED25DSXDW03
Whirlpool ED25DSXDW05
Whirlpool ED25DWXTF00
Whirlpool ED25DWXTF01
Whirlpool ED25DWXTF02
Whirlpool ED25DWXTF03
Whirlpool ED25DWXTF04
Whirlpool ED25DWXTF05
Whirlpool ED25DWXTG00
Whirlpool ED25DWXTG01
  #2 (permalink)
Old 01-16-2010, 11:40 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL ED25CQXHB01 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/w...%202186936.pdf
It is important that you be sure that the compressor is running. It should be warm and you should be able to feel it vibrating.
Remove the cover inside the freezer section so you can see the evaporator coils.
If they only have frost in one area, usually where the freon enters the coils from the compressor. You have a low freon condition.
If they have no frost then either the compressor is toast, you are out of freon or an orifice in the system is plugged.
Any of the above is usually the death knell for a fridge. You need a pro to repair it and it will not be cheap. Also there is no use in refilling a unit with freon unless the leak is found and repaired. This can be difficult.
Here is the warranty sheet for this unit so if it is under 5 years old the sealed system should be covered under warranty.
http://shared.whirlpoolcorp.com/asse...02205958-W.pdf
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
help fridge and freezer not cold at all fridge went first then the freezer did jeannie beck Refrigerator & Freezer Repair 1 02-22-2010 10:56 AM
Whirpool Light On In Freezer Not On In Fridge rosuch Refrigerator & Freezer Repair 0 02-14-2010 10:05 AM
Whirlpool fridge (bottom freezer style) top fridge shelf getting very cold dieselgg Refrigerator & Freezer Repair 5 06-19-2009 04:51 AM
freezer.fridge not cold and leaking into fridge fruitul Refrigerator & Freezer Repair 1 09-08-2008 03:20 PM
Fridge & Freezer Cycle Cold To Warm Back To Cold terkel Refrigerator & Freezer Repair 1 09-25-2007 02:58 AM
