jfkpak
#1 Posted : Saturday, January 9, 2010 12:51:58 PM(UTC)
jfkpak
my ice maker timer goes through cycle but the water control value does not recieve 120vac .Replace wiring harnes because had no voltage to motor module.Motor module goes through cycle but no water to tray.Water from dispensor side of value works fine.
magician59
#2 Posted : Saturday, January 9, 2010 7:10:27 PM(UTC)
magician59
Disconnect the wiring connector from the ice maker side of the valve. Also disconnect the water line that goes to the ice maker from the valve. Leave the other lines connected. Remove the valve and place it into a bucket or other non-metallic container. Apply 120VAC to the terminals just long enough to see if water flows from the valve. If not, replace the valve.
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
Whirlpool Gold Side by Side (GSS26C4XXF03/HR14386344) Door Ice Maker Troubleshooting (Refrigerator & Freezer Repair)
by ForumUser1 12/25/2023 11:44:03 AM(UTC)
Need service code to defrost Electrolux ice maker, EI23BC56ISB (Refrigerator & Freezer Repair)
by Guest 12/16/2023 12:29:49 PM(UTC)
Wiring harness clip KitchenAid freestanding ice maker KUIC18NNZS0 (Appliance Parts)
by GADIY 12/5/2023 12:02:09 PM(UTC)
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
