Discuss
Freezer icing up, fridge freezing, thermostat, timer, and defrost heater check out.
 in
Refrigerator & Freezer Repair
We recently went away for a month, and left our Amana fridge/freezer running. When re returned, the fridge compartment was
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer icing up, fridge freezing, thermostat, timer, and defrost heater check out.
  #1 (permalink)
Old 01-09-2010, 01:29 PM
Junior Member
sharkytm is on a distinguished road
Default Freezer icing up, fridge freezing, thermostat, timer, and defrost heater check out.
Model Number: ARB2214CB   Brand: Amana   Age: 1 - 5 years
We recently went away for a month, and left our Amana fridge/freezer running. When re returned, the fridge compartment was near-freezing (milk on top shelf ices up, nothing on the lower shelves freeze), and our freezer was filled with frost and ice. We defrosted the entire thing, and left it for a week, making sure that the door was securely sealed. Its started icing up again, and the milk is freezing again.
So, I took the back off the freezer compartment, and the controls from the fridge which is where the defrost timer is located. I had to cut one wire that led to the defrost thermostat, and tested it. When it is frozen, it has continuity, and when warmed up, it doesn't. In other words, it works fine. I checked the resistance of the defrost heater. It ohms out at 35 ohms (correct) and works fine. I also tested the defrost timer, by marking where it was with a Sharpie, and letting it advance. It advances as it should, hitting the defrost setting on the timer every 6 hours.
So... what else could it be? I'm wondering if the freezer thermostat is bad, or if there even is one. Is there a way to test the thermostat in the freezer control knob? No matter what I set it to, including off, it still runs the compressor full time.
Related Models
Amana ARB2214CB REF - BOTTOM MOUNTS
Amana ARB2214CC REF - BOTTOM MOUNTS
Amana ARB2214CSL REF - BOTTOM MOUNTS
Amana ARB2214CSR REF - BOTTOM MOUNTS
Amana ARB2214CW REF - BOTTOM MOUNTS
Amana ARB2217CB REF - BOTTOM MOUNTS
Amana ARB2217CC REF - BOTTOM MOUNTS
Amana ARB2217CSL REF - BOTTOM MOUNTS
Amana ARB2217CSR REF - BOTTOM MOUNTS
Amana ARB2217CW REF - BOTTOM MOUNTS
Amana ARB224RCB REF - BOTTOM MOUNTS
Amana ARB224RCC REF - BOTTOM MOUNTS
Amana ARB224RCW REF - BOTTOM MOUNTS
Amana ARB2257CB REF - BOTTOM MOUNTS
Amana ARB2257CC REF - BOTTOM MOUNTS
Amana ARB2257CSL REF - BOTTOM MOUNTS
Amana ARB2257CSR REF - BOTTOM MOUNTS
Amana ARB2257CW REF - BOTTOM MOUNTS
Amana ARB2259CB REF - BOTTOM MOUNTS
Amana ARB2259CC REF - BOTTOM MOUNTS
Amana ARB2259CS REF - BOTTOM MOUNTS
Amana ARB2259CW REF - BOTTOM MOUNTS
Amana ARB2517CB REF - BOTTOM MOUNTS
Amana ARB2517CC REF - BOTTOM MOUNTS
Amana ARB2517CSL REF - BOTTOM MOUNTS
Amana ARB2517CSR REF - BOTTOM MOUNTS
Amana ARB2517CW REF - BOTTOM MOUNTS
Amana ARB2557CB REF - BOTTOM MOUNTS
Amana ARB2557CC REF - BOTTOM MOUNTS
Amana ARB2557CSL REF - BOTTOM MOUNTS
Amana ARB2557CSR REF - BOTTOM MOUNTS
Amana ARB2557CW REF - BOTTOM MOUNTS
Amana ARB8057CB REF - BOTTOM MOUNTS
Amana ARB8057CC REF - BOTTOM MOUNTS
Amana ARB8057CSL REF - BOTTOM MOUNTS
Amana ARB8057CSR REF - BOTTOM MOUNTS
Amana ARB8057CW REF - BOTTOM MOUNTS
Amana ARB9058CB REF - BOTTOM MOUNTS
Amana ARB9058CS REF - BOTTOM MOUNTS
Amana ARB9058CW REF - BOTTOM MOUNTS
Amana ARB9059CS REF - BOTTOM MOUNTS
Amana ARC-1 RANGE- S/C S/I DDRAFT GAS
Amana ARC-100 RANGE- S/C S/I DDRAFT GAS
Amana ARC-100B RANGE- S/C S/I DDRAFT GAS
Amana ARC-1B RANGE- S/C S/I DDRAFT GAS
Amana ARC-2 RANGE- S/C S/I DDRAFT GAS
Amana ARC-2B RANGE- S/C S/I DDRAFT GAS
Amana ARC-506 RANGE- S/C S/I DDRAFT ELE
Amana ARC100B RANGE- S/C S/I DDRAFT ELE
Amana ARC100D RANGE- S/C S/I DDRAFT ELE
Amana ARC1B RANGE- S/C S/I DDRAFT ELE
Amana ARC502W RANGE- S/C S/I DDRAFT ELE
Amana ARC505 RANGE- S/C F/S ELE
Amana ARC505B RANGE- S/C S/I DDRAFT ELE
Amana ARC515 RANGE- S/C S/I DDRAFT ELE
Amana ARC515 RANGE- S/C S/I DDRAFT GAS
Amana ARC700E Range - S/c S/i Ddraft Ele
Amana ARC700E RANGE- S/C S/I DDRAFT ELE
Amana ARC700LL RANGE- S/C S/I DDRAFT ELE
Amana ARC700WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS800E RANGE- S/C S/I DDRAFT ELE
Amana ARDS800WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS801E RANGE- S/C S/I DDRAFT ELE
Amana ARDS801WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS802E RANGE- S/C S/I DDRAFT ELE
Amana ARDS802SS RANGE- S/C S/I DDRAFT ELE
Amana ARDS802WW RANGE- S/C S/I DDRAFT ELE
Amana ARE14 MISC / ACCESSORY
Amana ARE640 RANGE- S/C S/I DDRAFT GAS
Amana ARE640 RANGE- S/C S/I DDRAFT ELE
Amana ARE650 RANGE- S/C S/I DDRAFT GAS
Amana ARE650 RANGE- S/C S/I DDRAFT ELE
Amana ARG3600L RANGE- S/C S/I DDRAFT GAS
Amana ARG3600LL RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 01-09-2010, 08:24 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
The freezing in the refrigerator compartment suggests a problem with the damper. It may be blocked with ice, or food. It would also be a good idea to check the operation of the evaporator and condenser fans. They should both work when the compressor is running. Is the top of the compressor hot when it's running, or cold?
  #3 (permalink)
Old 01-09-2010, 08:35 PM
Junior Member
Default
The fans are working fine, as is the damper. I pulled the freezer control thermostat out, and its dead. Even in the off position, there's continuity between the switched pins.
If I'm correct, the freezer has been running constantly (except when the its in defrost mode) and even though the fridge damper is mostly closed (setting of 1), the air from the freezer is cold enough to freeze the fridge.
So, $38+s/h, and I'll know for sure.
  #4 (permalink)
Old 01-09-2010, 09:40 PM
Senior Expert
APP Volunteer
Default
There's your problem...well done!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replaced the heater, thermostat and defrost timer but it's still not right? mandal Refrigerator & Freezer Repair 3 08-06-2017 05:38 AM
freezer icing up - which circ. board contains the defrost timer? frankv Refrigerator & Freezer Repair 5 08-27-2010 04:07 PM
Freezer cool, Fridge warm already replaced timer and heater tadnsis Refrigerator & Freezer Repair 8 10-17-2009 09:04 AM
Where is defrost timer located on my fridge, plus testing thermostat pmpm Refrigerator & Freezer Repair 1 05-28-2009 01:18 PM
How do I check the defrost timer, heater, and thermostat and repair whats wrong elgem3 Refrigerator & Freezer Repair 1 10-26-2008 04:36 PM
