I ordered water valves and relay with the wiring harness for my GE fridge( mod# TFX25ZPBBWW). The wiring harness connector is wired backwards. It is flat on one side and can only plug in one way. I called the parts store and talked with Dremal. He said there is a "universal wiring harness" (AP2067740) that will correct this problem. I looked the harness up and I don't understand how this harness can work. If you use this harness, I don't see how you would connect to the relay. When I connect the harness, I can get water to the dispenser but not to the ice maker. I think I need the correct relay and wiring harness.Please advise. If you can help in anyway, it would be appreciated.
