Discuss
GE Fridge ice maker works, water dispenser does not
 in
Refrigerator & Freezer Repair
GE Fridge ice maker works, water dispenser does not. The ice maker not only dispenses ice, it is still making
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE Fridge ice maker works, water dispenser does not
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-30-2008, 11:48 AM
Stevenn1 Stevenn1 is offline
Junior Member
Stevenn1 is on a distinguished road
Question GE Fridge ice maker works, water dispenser does not
Model Number: GSS25WGPD WW   Brand: GE   Age: 1 - 5 years
GE Fridge ice maker works, water dispenser does not. The ice maker not only dispenses ice, it is still making it too. Side by side unit. The dispenser is located on the outside of the freezer door. What went wrong?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-31-2008, 10:55 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Assuming the ice dispenser works fine, the first thing I would check is the water filter, then the water inlet valve on the back of the fridge.
If the water filter is more than a year old it will cause restriction to the water flow.
Locate the water inlet valve on the back of the fridge. Remove the wires from the blue solenoid and check for 120V coming to the solenoid while the water dispenser lever is depressed.
If there is 120V then the water inlet valve has to be replaced.
If there is no 120V then the main control board (on the back panel of the fridge) has to be replaced.
- The part number for the water filter is AP3859302
- The part number for the water inlet valve is AP3192626
- The part number for the main control board is AP3950129
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 04-22-2008, 08:04 AM
RonG RonG is offline
Junior Member
RonG is on a distinguished road
Default
Gene,
I believe I have the save problem as Stevenn1, different model. It has nothing to do with water. The ice maker is producing ice to capacity. The in door water dispenser delivers water. But when you switch the in door dispenser to cubed or crushed ice, absolutely nothing happens. Not a sound. The green light on the door indicating I switched the dispenser from water to cubed lights but nothing happens when I push the glass against the lever unless I want water. The first guess was the motor that drives the auger but that was actually fine. But even if it was that motor, wouldn't the ice crusher motor grind if it was in that mode? I'm guessing no signal is leaving the door to tell the auger and ice crusher to work.
RonG
  #4 (permalink)
Old 04-22-2008, 05:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Ron,
In order to provide most accurate advise we need the complete model number of the refrigerator.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water dispenser works some days and not others carsons15 Refrigerator & Freezer Repair 1 03-23-2008 01:09 PM
ice maker / water dispenser problems krkoch Refrigerator & Freezer Repair 0 03-08-2008 02:56 PM
Ice maker will not draw water but water in door works normally kg1okc Refrigerator & Freezer Repair 3 01-26-2008 02:57 PM
Water Won't Dispense Ice Maker Works PAULUS1024 Refrigerator & Freezer Repair 5 11-26-2007 06:21 PM
Water Dispenser/Ice Maker not working Michael_Timberblind Refrigerator & Freezer Repair 3 09-02-2007 06:16 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
