LeRoyKinkade
#1 Posted : Saturday, January 9, 2010 8:58:56 AM(UTC)
LeRoyKinkade
I Moved a fridge for a friend, when trying to remove the comp. ftg. from the valve, the fitting itself spun in the plastic valve body. after trying a few different fixes, the ftg. popped out of the valve body. now the ftg. wont seal in the valve body.
is there a way to fix this without replacing the entire Valve?
Very grateful for any help, thanks.
ApplianceJunk
#2 Posted : Saturday, January 9, 2010 12:01:23 PM(UTC)
ApplianceJunk
If the threads are stripped out on the body of the water valve then you will have to replace the valve.
LeRoyKinkade
#3 Posted : Sunday, January 10, 2010 9:06:47 AM(UTC)
LeRoyKinkade
There are no threads in the valve body, the comp. ftg. has what appears to be a friction fit, with a small O ring near the bottom: this contributes greatly to the ftg. spinning in the valve body. Thanks
