| » Removing evap motor |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: GDS18LBR Brand: GE Age: 1 - 5 years
My 3 yr old fridge is not blowing cold. suspect evap is frozen or fan is bad.
I checked defrost timer ohms out fine. I want to get to evap fan but not sure how to access. This is a bottom freezer top fridge model. Till I get some info I have removed food and turned off power going to let it melt down overnight and see if evap fan runs tomorrow. I will still want to check out evap heater and defrost t-stat. thx |
Empty freezer. remove icemaker if present. should have 4 screws holding the back freezer panel in. Sometimes the blade is pushed too far on the motor shaft so check that first. check voltage at fan. replace if needed. easy stuff you'll have no problems.
| Display Modes | |
| GE evap fan/circuit problem | jbos | Refrigerator & Freezer Repair | 4 | 03-17-2008 04:05 AM |
| GE Evap fan motor replacement | JoeW | Refrigerator & Freezer Repair | 8 | 03-04-2008 04:38 AM |
| Noisy Evap Fan | hamm_6869 | Refrigerator & Freezer Repair | 3 | 12-28-2007 11:48 AM |
| ge fridge question..6 vs 4 wires into evap harness? | mpodols | Refrigerator & Freezer Repair | 1 | 11-21-2007 11:08 AM |
| Removing pump motor assembly | dcherioke1 | Dishwasher Repair | 1 | 09-14-2007 10:50 AM |
