| » Wire harness broken in freezer door |
Model Number: GC5SHGXKT00 Brand: Whirlpool Age: 1 - 5 years
I have a wire harness that has several broken wires near the bottom of the freezer door that have been damaged over time. The water line was orginally broken but many others were partially cut also. I have been trying unsucessfully to reattached the wires with some butt connectors but they will not stay together after opening and closing the door several times. The result is no water, no ice, no light. These are very hard to splice as they are right near the enrty into the door.
I'd like to know if the wire harness can be replaced or do I need to purchase the entire freezer door. It looks like there is not a connection at the bottom of the door to release. but I could be wrong. It enters into an elbow that is screwed to the bottom. I found wire harness AP3133416 made by WHIRLPOOL per a diagram I saw, but this does not look like the wire harness I need. Any help is appreciated Ads By Google Related Models |
In order to replace the wire harness - the inner door panel has to be removed. Unfortunately the freezer door in your fridge does not come apart by design and the only solution is to replace the whole door.
In order to provide the right part number for the freezer door I need the color of the unit. You can find the complete instructions on how to remove the freezer door in the service manual (page 4-23). Here are the break down diagrams for the Whirlpool refrigerator Model GC5SHGXKT00 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Color is Biscuit on Biscuit. This is too bad. The repaiman who serviced my refrigerator initially said he fixed this issue but I later came to find out he just used electrical tape to hold them together. I wonder if it is worth the try to solder/splice some new wires. It is almost better to just buy a new fridge.
If you can provide the part number for a door this would be great Thanks Gene! |
__________________
I may have the same problem only mine is a Frigidaire M/N: FRS24ZSGB0.
I have no water/ice/light. I have not checked the connection, but it worked this past weekend when I unfroze the drain plug in the freezer. Is it possible to replace the wire harness or is it the door for me too. Would it be possible to splice in a new connector? |
| Display Modes | |
| How do I install the freezer door wiring harness? | jrk | Refrigerator & Freezer Repair | 2 | 01-30-2012 06:43 PM |
| wire harness for whirlpool #RS675PXQ015 | MAINTENANCE MAN | Appliance Parts | 0 | 12-17-2009 12:49 PM |
| Timer/ harness wire diagram | filbo_1958 | Dishwasher Repair | 3 | 11-02-2009 01:14 AM |
| Switch Wire Harness | alanbarry | Oven Repair (including Ranges and Cooktops) | 0 | 02-25-2009 02:18 PM |
