I have a Samsung RB195ZASH. The ice maker is able to make ice, however, when it dumps the ice, it starts making a loud popping noise for about a minute or two.
I looked at it and saw that the plastic tray for the ice is getting caught on its way around on another plastic piece in the ice maker. After the 1 - 2 minutes, it is able to move past the other plastic piece and start making ice again.
Is there an easy solution to this problem?
I had the same problem. I replaced the ice maker with a new one and the problem is solved.
