Hi everyone. I have side by side and it still looks good so I would like to fix it. It has little cooling noticeable only at the evaporator. Initial test after tapping the low side was showing vacuum while still charged when I run the fridge. I recovered the full charge of R134A, 5.3oz. Filter/dryer isn' clogged. I cut capillary tubing from the filter/dryer side and snaked by guitar string. No obstruction felt but couldn't reach to the evap. due to the string length. I was blowing air through it, it has some resistance so I am trying to figure out how much resistance it should have so it's not clogged. Compressor is pulling 25inHg is short time while capillary disconnected at the filter/dryer side and after shutdown it levels out with outside pressure within about 4 minutes so I am not sure if the time is too long which would indicate some clog or if it's correct. Thanks for attention.
