Discuss
Whirlpool GD25DIXHS02 REMOVING CONTROL BOX
 in
Refrigerator & Freezer Repair
I have a Conquest unit. I think the defrost timer or relay is bad. I need to get inside the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool GD25DIXHS02 REMOVING CONTROL BOX
  #1 (permalink)
Old 01-07-2010, 06:28 AM
Junior Member
needhelp123 is on a distinguished road
Smile Whirlpool GD25DIXHS02 REMOVING CONTROL BOX
Model Number: GD25DIXHS02   Brand: Whirlpool   Age: 5 - 10 years
I have a Conquest unit. I think the defrost timer or relay is bad. I need to get inside the control box to check it. I removed the two hex screws that hold it, but it will not come off. It pivots to the front( the back is loose, but I do not want to force anything. Can anyone help explain the "trick" to getting this off. Thanks. My frig is up to 65,now!
If case someone can help, I will provide more info on the problem. This frig for the past two years or so has had a problem with water pooling in front of the unit. I found that the defrost water line was getting plugged with ice. I would shut the unit off and use a hairdryer and hot water to unplug it. Over the past week I have noticed the frig getting warmer and the freezer is not as cold. I see that there is thick frost on the entire pack of the freezer compartment.
THANK!
Ads By Google
Related Models
Whirlpool GD25DIXHT00
Whirlpool GD25DIXHT02
Whirlpool GD25DIXHW00
Whirlpool GD25DIXHW02
Whirlpool GD25DQXFB00
Whirlpool GD25DQXFB01
Whirlpool GD25DQXFN00
Whirlpool GD25DQXFN01
Whirlpool GD25DQXFW00
Whirlpool GD25DQXFW01
Whirlpool GD25FFCHB00 Refrigerator
Whirlpool GD25FFCHB01
Whirlpool GD25FFCHT00 Refrigerator
Whirlpool GD25FFCHT01
Whirlpool GD25FFCHW00 Refrigerator
Whirlpool GD25FFCHW01
Whirlpool GD25SFCHS10
Whirlpool GD25SFCHS11
Whirlpool GD25SFCHS111
Whirlpool GD25SFXHS00
Whirlpool GD25SFXHS01
Whirlpool GD25SFXHS02
Whirlpool GD25SFXHS03
Whirlpool GD25SFXHS04
Whirlpool GD25SFXHS05
Whirlpool GD25SHAXLB01
Whirlpool GD25SHAXLQ01
Whirlpool GD25SHAXLT01
Whirlpool GD25SSFCHS10
Whirlpool GD27DFXFB00
Whirlpool GD27DFXFB01
Whirlpool GD27DFXFB02
Whirlpool GD27DFXFB03
Whirlpool GD27DFXFN00
Whirlpool GD27DFXFN01
Whirlpool GD27DFXFN02
Whirlpool GD27DFXFN03
Whirlpool GD27DFXFT02
Whirlpool GD27DFXFT03
Whirlpool GD27DFXFW00
Whirlpool GD27DFXFW01
Whirlpool GD27DFXFW02
Whirlpool GD27DFXFW03
Whirlpool GD27DIXHB00
Whirlpool GD27DIXHB01
Whirlpool GD27DIXHB02
Whirlpool GD27DIXHS00
Whirlpool GD27DIXHS01
Whirlpool GD27DIXHS02
Whirlpool GD27DIXHT00
Whirlpool GD27DIXHT01
Whirlpool GD27DIXHT02
Whirlpool GD27DIXHW00
Whirlpool GD27DIXHW01
Whirlpool GD27DIXHW02
Whirlpool GD27DQXFB00
Whirlpool GD27DQXFB01
Whirlpool GD27DQXFN00
Whirlpool GD27DQXFN01
Whirlpool GD27DQXFW00
Whirlpool GD27DQXFW01
Whirlpool GD2LHGXKB00
Whirlpool GD2LHGXKQ00
Whirlpool GD2LHGXKT00
Whirlpool GD2LHGXLB00
Whirlpool GD2LHGXLB01
Whirlpool GD2LHGXLB03
Whirlpool GD2LHGXLB04
Whirlpool GD2LHGXLQ00
Whirlpool GD2LHGXLQ01
Whirlpool GD2LHGXLQ03
Whirlpool GD2LHGXLQ04
Whirlpool GD2LHGXLT00
Whirlpool GD2LHGXLT01
Whirlpool GD2LHGXLT03
Whirlpool GD2LHGXLT04
Whirlpool GD2NHAXMB00 Refrigerator
Whirlpool GD2NHAXMQ00 Refrigerator
Whirlpool GD2NHAXMT00 Refrigerator
Whirlpool GD2NHGXKB01
Whirlpool GD2NHGXKB02
Whirlpool GD2NHGXKQ01
Whirlpool GD2NHGXKQ02
Whirlpool GD2NHGXKT01
Whirlpool GD2NHGXKT02
Whirlpool GD2NHGXLQ00
Whirlpool GD2NHGXLT00
Whirlpool GD2SHAXKB01
Whirlpool GD2SHAXKB02
Whirlpool GD2SHAXKB03
Whirlpool GD2SHAXKQ01
Whirlpool GD2SHAXKQ02
Whirlpool GD2SHAXKQ03
Whirlpool GD2SHAXKT01
Whirlpool GD2SHAXKT02
Whirlpool GD2SHAXKT03
Whirlpool GD2SHAXLB00
Whirlpool GD2SHAXLB02
Whirlpool GD2SHAXLQ00
Whirlpool GD2SHAXLQ02
Whirlpool GD2SHAXLT00
Whirlpool GD2SHAXLT02
Whirlpool GD2SHAXMB00 Refrigerator
Whirlpool GD2SHAXMQ00 Refrigerator
Whirlpool GD2SHAXMT00 Refrigerator
Whirlpool GD2SHAXNB00 Refrigerator
Whirlpool GD2SHAXNB01 Refrigerator
Whirlpool GD2SHAXNL00 Refrigerator
Whirlpool GD2SHAXNL01 Refrigerator
Whirlpool GD2SHAXNQ00 Refrigerator
Whirlpool GD2SHAXNQ01 Refrigerator
Whirlpool GD2SHAXNS00 Refrigerator
Whirlpool GD2SHAXNS01 Refrigerator
Whirlpool GD2SHAXNT00 Refrigerator
Whirlpool GD2SHAXNT01 Refrigerator
Whirlpool GD2SHGXKB01
Whirlpool GD2SHGXKB02
Whirlpool GD2SHGXKQ01
Whirlpool GD2SHGXKQ02
  #2 (permalink)
Old 01-07-2010, 06:52 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL GD25DIXHS02 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/w...%202198693.pdf
You may not have to get at the defrost timer.
See in the tech sheet on how to force a defrost cycle.
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle see the tech sheet.
When the fans and compressor turn off, you are in a defrost cycle.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
__________________
  #3 (permalink)
Old 01-07-2010, 07:05 AM
Junior Member
Default control box, defrost
We I got the box cover off, but do not see how to "adjust the timer.
  #4 (permalink)
Old 01-07-2010, 07:58 AM
Junior Member
Default
I have an ohm meter. It is not easy to get to the back of the unit. I touched the ohm leads to insure it registers resistance. When I disconnect one side and try to get a reading, I get none. Is ther eanother way to check the heater element before removing it. IT seems liek it woul dnot be an item that would fail.
  #5 (permalink)
Old 01-07-2010, 07:59 AM
Senior Expert
APP Volunteer
Default
It is an electronic timer, you cannot adjust it.
It monitors the number of times the door is opened and then adjusts the defrost cycle frequency to this.
To force a defrost cycle use the procedure in the tech sheet.
__________________
  #6 (permalink)
Old 01-07-2010, 08:16 AM
Junior Member
Default
Just thought of something. If the heater coil is the issue can I remove it and check it by just running 120 v through it to see if it heats?
  #7 (permalink)
Old 01-07-2010, 08:18 AM
Junior Member
Default
yse, I did this and it does not work. I checked the ohms on the heater and it does not appear to have any resistance.
  #8 (permalink)
Old 01-07-2010, 08:51 AM
Senior Expert
APP Volunteer
Default
Strange that you could not force a defrost cycle.
This may indicate that the defrost timer is also shot but I would change the defrost element first.
Just to clarify as some people say it has no resistance when there meter reads a zero. When in reality the meter is just on too high of a scale and the device is OK
So if you are reading infinite resistance (an open) then the heater is toast.
I would also check the defrost thermostat, it should be 0 ohms when frozen.
Also if it looks bulged out I would replace it as water has gotten into it and it will fail in the near future.
__________________
  #9 (permalink)
Old 01-07-2010, 09:08 AM
Junior Member
Default defrost coil
NOt sure if you saw my reply to this. I wanted to hear back befreo disassembling the coil. Can you get it out form behind the cooling refrig coils without to much difficulty?
  #10 (permalink)
Old 01-07-2010, 02:58 PM
Junior Member
Default
Thanks, I will take out the element first and double check the resistance. I cleaned the ice from everything and plugged the frig back in and it gets cold, so I know I have the correct general problem area identified.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Removing control panel One More Try Refrigerator & Freezer Repair 0 02-02-2010 02:37 PM
Need guidance on removing control panel NCAmy Oven Repair (including Ranges and Cooktops) 1 10-30-2009 03:42 PM
Removing Control Knob MLL Washer Repair 1 10-21-2008 10:49 AM
Need help removing front control panel owenwalk Oven Repair (including Ranges and Cooktops) 1 09-25-2008 04:28 PM
Removing the control panel - how to do it???? sean_lui Microwave Repair 1 07-28-2008 10:19 AM
