I took my ice maker apart and now need to figure out where the ice maker "fingers" ( that push ice out of mold ) should be positioned in relation to the plastic gear that turns it. The gear fits on the shaft in two different positions, and I'm not sure which way to position it. There is a notch with a red line on the gear that may indicate if it should be at the 10 o'clock or the 5 o'clock position when the fingers are at the 2 o'clock postion when looking at it from control modual. Any ideas? Thanks
