My Ice Maker stoped working. I did notice ice in the fill tube which I melted with hair dryer. The optics seem O.K., I checked like you suggested on other posts. Light blinks 2X then pause, then repeats. When I close flapper on other side, light stays solid. I tested points L & N with a volt meter and I get 5 volts. I checked voltage at coupling harnes and it shows 114 V. I tried jumping T & H and nothing happens. Should I have 120 V at L & N at all times? What do you think the proplem is? Thanks,Pat
