PatchesDad
#1 Posted : Monday, December 21, 2009 10:13:58 AM(UTC)
PatchesDad
My fridge keeps filling with water at the bottom under the crisper drawers, which causes rusting underneath the seams there. What causes this build up of water. And it is not a little bit of water, and it only takes a couple of days to build up again. I think it may be the drain from the freezer but I have no idea how to fix that.
Qtip
#2 Posted : Monday, December 21, 2009 5:58:09 PM(UTC)
Qtip
yeah your most lilely problem is a clogged drain. the drain is about the size of a dime and usually a pea or something gets clogged in that drain which causes the water to back up in the fridge. you will have to locate the drain and melt all the ice away from the drain and then use a turkey baster with hot water and spray it into the drain until the drain clears. its very hard to tell if the drain has been completely cleared or not so if the problem comes back after clearing it then you know there is still something stuck inthere.
Electrolux Refrigerator not getting cold (Refrigerator & Freezer Repair)
by jesus freak 3/30/2024 1:11:55 AM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Built-In Kitchenaid Mdel KSSC42QMS00 Refrigerator (Refrigerator & Freezer Repair)
by Guest 3/25/2024 6:29:18 AM(UTC)
Samsung Refrigerator - Service Kit for Icing Issue (Refrigerator & Freezer Repair)
by keith1386 3/24/2024 8:57:57 AM(UTC)
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Maytag Refrigerator freezing food on lowest setting (Refrigerator & Freezer Repair)
by ilgy 2/15/2024 8:14:17 AM(UTC)
EA120 EA150 Bosch Error Code - Built In Refrigerator (Refrigerator & Freezer Repair)
by Peter Franks 2/13/2024 4:55:41 PM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Power Surge damage to Refrigerator and Clothes Drier (Refrigerator & Freezer Repair)
by CBorucki 1/21/2024 7:29:43 AM(UTC)
Frigidaire Refrigerator model 253.56602402 issue (Refrigerator & Freezer Repair)
by anitak4242 1/17/2024 8:32:53 PM(UTC)
Whirlpool Refrigerator question (Dishwasher Repair)
by staffx4 1/9/2024 11:15:21 AM(UTC)
Frigidaire Gallery Refrigerator GRFS2853AF4 - Freezer not working (Refrigerator & Freezer Repair)
by Repaircat 1/9/2024 8:08:53 AM(UTC)
Frigidaire Refrigerator FRS24XGCB1 (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:18:22 PM(UTC)
refrigerator compressor clicking off (Refrigerator & Freezer Repair)
by rleescott 12/22/2023 4:57:43 AM(UTC)
