Icemaker wasn't working although LED light was on....purchased new icemaker (IM6) and plugged it in...it has cycled 3 times in 15 hours...hardly any ice...temperature is 8 degrees F in freezer....tested water valve by supplying 110 volts to the terminals...water comes through just fine....can't figure this out?????????????:mad:
