Discuss
defrost heater
 in
Refrigerator & Freezer Repair
The evaporator will freeze up with lots of ice. The defrost heater is getting hot, but not glowing red like
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » defrost heater
  #1 (permalink)
Old 03-19-2008, 03:30 AM
Junior Member
Kenny Duke is on a distinguished road
Default defrost heater
Model Number: CRFS14   Brand: Amana   Age: More than 10 years
The evaporator will freeze up with lots of ice. The defrost heater is getting hot, but not glowing red like I have seen on other elements in the past. Is this one supposed to glow red?
Ads By Google
Related Models
Amana CRFS14 Misc / Accessory
Amana CRFS14L Misc / Accessory
Maytag CRG0305AAL Range - F/s Std Gas
Maytag CRG0560AAW Range - F/s Std Gas
Maytag CRG0760AAL Range - S/c F/s Gas
Maytag CRG0760AAW Range - S/c F/s Gas
Maytag CRG0860AAL Range - S/c F/s Gas
Maytag CRG0860AAW Range - S/c F/s Gas
Maytag CRG200 Range - F/s Std Gas
Maytag CRG200B Range - F/s Std Gas
Maytag CRG300 Range - F/s Std Gas
Maytag CRG300B Range - F/s Std Gas
Maytag CRG305 Range - F/s Std Gas
Maytag CRG350 Range - F/s Std Gas
Maytag CRG350B Range - F/s Std Gas
Maytag CRG355 Range - F/s Std Gas
Maytag CRG382 Range - F/s Std Gas
Maytag CRG383 Range - F/s Std Gas
Maytag CRG400 Range - F/s Std Gas
Maytag CRG400B Range - F/s Std Gas
Maytag CRG405 Range - F/s Cont Clean Gas
Maytag CRG500 Range - F/s Std Gas
Maytag CRG501 Range - F/s Std Gas
Maytag CRG501B Range - F/s Std Gas
Maytag CRG502 Range - F/s Std Gas
Maytag CRG505 Range - F/s Std Gas
Maytag CRG560 Range - F/s Std Gas
Maytag CRG560A Range - F/s Std Gas
Maytag CRG583 Range - F/s Cont Clean Gas
Maytag CRG600 Range - F/s Std Gas
Maytag CRG601 Range - F/s Std Gas
Maytag CRG602 Range - F/s Cont Clean Gas
Maytag CRG700 Range - S/c F/s Gas
Maytag CRG705 Range - S/c F/s Gas
Maytag CRG7400AAL Range - F/s Std Gas
Maytag CRG7400AAW Range - F/s Std Gas
Maytag CRG7400BAL Range - F/s Std Gas
Maytag CRG7400BAW Range - F/s Std Gas
Maytag CRG7400CAE Range - F/s Std Gas
Maytag CRG7400CAL Range - F/s Std Gas
Maytag CRG7400CAW Range - F/s Std Gas
Maytag CRG750 Range - S/c F/s Gas
Maytag CRG7500AAE Range - F/s Std Gas
Maytag CRG7500AAL Range - F/s Std Gas
Maytag CRG7500AAW Range - F/s Std Gas
Maytag CRG7500CAE Range - F/s Std Gas
Maytag CRG7500CAL Range - F/s Std Gas
Maytag CRG7500CAW Range - F/s Std Gas
International CRG7500CGE Range - F/s Std Gas
International CRG7500CGL Range - F/s Std Gas
International CRG7500CGW Range - F/s Std Gas
Maytag CRG755 Range - S/c F/s Gas
Maytag CRG760 Range - S/c F/s Gas
Maytag CRG7600AAL Range - F/s Cont Clean Gas
Maytag CRG7600AAW Range - F/s Cont Clean Gas
Maytag CRG760A Range - S/c F/s Gas
Maytag CRG7700AAL Range - F/s Std Gas
Maytag CRG7700AAW Range - F/s Std Gas
Maytag CRG7700BAL Range - F/s Std Gas
Maytag CRG7700BAW Range - F/s Std Gas
Maytag CRG7700CAL Range - F/s Std Gas
Maytag CRG7700CAW Range - F/s Std Gas
Maytag CRG783 Range - S/c F/s Gas
Maytag CRG800 Range - S/c F/s Gas
Maytag CRG805 Range - S/c F/s Gas
Maytag CRG8200AAL Range - F/s Std Gas
Maytag CRG8200AAW Range - F/s Std Gas
Maytag CRG8200BAL Range - F/s Std Gas
Maytag CRG8200BAW Range - F/s Std Gas
Maytag CRG8200CAL Range - F/s Std Gas
Maytag CRG8200CAW Range - F/s Std Gas
Maytag CRG8400AAL Range - F/s Std Gas
Maytag CRG8400AAW Range - F/s Std Gas
Maytag CRG860 Range - S/c F/s Gas
Maytag CRG8600AAB Range - S/c F/s Gas
Maytag CRG8600AAL Range - S/c F/s Gas
Maytag CRG8600AAW Range - S/c F/s Gas
Maytag CRG8600BAB Range - S/c F/s Gas
Maytag CRG8600BAL Range - S/c F/s Gas
Maytag CRG8600BAW Range - S/c F/s Gas
Maytag CRG860A Range - S/c F/s Gas
Maytag CRG9300CAL Range - S/c F/s Gas
Maytag CRG9300CAW Range - S/c F/s Gas
Maytag CRG9600AAL Range - S/c F/s Gas
Maytag CRG9600AAW Range - S/c F/s Gas
Maytag CRG9700AAL Range - S/c F/s Gas
Maytag CRG9700AAW Range - S/c F/s Gas
Maytag CRG9700BAL Range - S/c F/s Gas
Maytag CRG9700BAW Range - S/c F/s Gas
Maytag CRG9700CAE Range - S/c F/s Gas
Maytag CRG9700CAL Range - S/c F/s Gas
Maytag CRG9700CAM Range - S/c F/s Gas
Maytag CRG9700CAW Range - S/c F/s Gas
International CRG9700CGE Range - S/c F/s Gas
International CRG9700CGM Range - S/c F/s Gas
Maytag CRG9800AAB Range - S/c F/s Gas
Maytag CRG9800AAE Range - S/c F/s Gas
Maytag CRG9800AAL Range - S/c F/s Gas
Maytag CRG9800AAW Range - S/c F/s Gas
Maytag CRG9800BAB Range - S/c F/s Gas
Maytag CRG9800BAE Range - S/c F/s Gas
Maytag CRG9800BAL Range - S/c F/s Gas
Maytag CRG9800BAM Range - S/c F/s Gas
Maytag CRG9800BAW Range - S/c F/s Gas
Maytag CRG9800CAB Range - S/c F/s Gas
Maytag CRG9800CAE Range - S/c F/s Gas
Maytag CRG9800CAM Range - S/c F/s Gas
Maytag CRG9830CAB Range - S/c F/s Gas
Maytag CRG9830CAE Range - S/c F/s Gas
Maytag CRG9830CAM Range - S/c F/s Gas
Admiral CRGA250AAL Range - F/s Std Gas
Admiral CRGA250AAW Range - F/s Std Gas
Admiral CRGA250BAL Range - F/s Std Gas
Admiral CRGA250BAW Range - F/s Std Gas
Admiral CRGA300AAL Range - F/s Std Gas
Admiral CRGA300AAW Range - F/s Std Gas
Admiral CRGA300BAL Range - F/s Std Gas
Admiral CRGA300BAW Range - F/s Std Gas
Admiral CRGA350AAL Range - F/s Std Gas
Admiral CRGA350AAW Range - F/s Std Gas
  #2 (permalink)
Old 03-19-2008, 01:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Kenny,
The defrost heater in your fridge should be very hot to touch but should not glow red for a safety reason.
If the defrost heater is hot during the defrost cycle and the fridge goes on defrost as often as it should then there is nothing wrong.
Did you check the evaporator fan motor?
The model number you posted does not come up.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
defrost heater jtra Refrigerator & Freezer Repair 0 07-28-2009 04:35 PM
Defrost heater George1980 Refrigerator & Freezer Repair 1 06-29-2009 08:49 AM
GE Defrost problem (Defrost heater fuses ?) rkpatt Refrigerator & Freezer Repair 0 08-03-2008 05:24 AM
defrost heater chillybill134 Refrigerator & Freezer Repair 0 01-17-2008 06:39 PM
Defrost heater Johnkut Refrigerator & Freezer Repair 9 12-26-2007 06:28 PM
