Discuss
Freezer cold but everythink has frost on it.
 in
Refrigerator & Freezer Repair
Freezer is at proper temperature. There is frost on everything and the unit keeps running. Turned defrost knob until it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer cold but everythink has frost on it.
  #1 (permalink)
Old 12-15-2009, 05:01 PM
Junior Member
KayS is on a distinguished road
Default Freezer cold but everythink has frost on it.
Model Number: ARB2118BW1   Brand: Amana   Age: 1 - 5 years
Freezer is at proper temperature. There is frost on everything and the unit keeps running. Turned defrost knob until it clicked. Still kept running. No ice buildup. Coils are not dirty.
Related Models
Amana ARB2205CB REF - BOTTOM MOUNTS
Amana ARB2205CC REF - BOTTOM MOUNTS
Amana ARB2205CS REF - BOTTOM MOUNTS
Amana ARB2205CW REF - BOTTOM MOUNTS
Amana ARB220RCB REF - BOTTOM MOUNTS
Amana ARB220RCC REF - BOTTOM MOUNTS
Amana ARB220RCW REF - BOTTOM MOUNTS
Amana ARB220ZCB REF - BOTTOM MOUNTS
Amana ARB220ZCC REF - BOTTOM MOUNTS
Amana ARB220ZCS REF - BOTTOM MOUNTS
Amana ARB220ZCW REF - BOTTOM MOUNTS
Amana ARB2214CB REF - BOTTOM MOUNTS
Amana ARB2214CC REF - BOTTOM MOUNTS
Amana ARB2214CSL REF - BOTTOM MOUNTS
Amana ARB2214CSR REF - BOTTOM MOUNTS
Amana ARB2214CW REF - BOTTOM MOUNTS
Amana ARB2217CB REF - BOTTOM MOUNTS
Amana ARB2217CC REF - BOTTOM MOUNTS
Amana ARB2217CSL REF - BOTTOM MOUNTS
Amana ARB2217CSR REF - BOTTOM MOUNTS
Amana ARB2217CW REF - BOTTOM MOUNTS
Amana ARB224RCB REF - BOTTOM MOUNTS
Amana ARB224RCC REF - BOTTOM MOUNTS
Amana ARB224RCW REF - BOTTOM MOUNTS
Amana ARB2257CB REF - BOTTOM MOUNTS
Amana ARB2257CC REF - BOTTOM MOUNTS
Amana ARB2257CSL REF - BOTTOM MOUNTS
Amana ARB2257CSR REF - BOTTOM MOUNTS
Amana ARB2257CW REF - BOTTOM MOUNTS
Amana ARB2259CB REF - BOTTOM MOUNTS
Amana ARB2259CC REF - BOTTOM MOUNTS
Amana ARB2259CS REF - BOTTOM MOUNTS
Amana ARB2259CW REF - BOTTOM MOUNTS
Amana ARB2517CB REF - BOTTOM MOUNTS
Amana ARB2517CC REF - BOTTOM MOUNTS
Amana ARB2517CSL REF - BOTTOM MOUNTS
Amana ARB2517CSR REF - BOTTOM MOUNTS
Amana ARB2517CW REF - BOTTOM MOUNTS
Amana ARB2557CB REF - BOTTOM MOUNTS
Amana ARB2557CC REF - BOTTOM MOUNTS
Amana ARB2557CSL REF - BOTTOM MOUNTS
Amana ARB2557CSR REF - BOTTOM MOUNTS
Amana ARB2557CW REF - BOTTOM MOUNTS
Amana ARB8057CB REF - BOTTOM MOUNTS
Amana ARB8057CC REF - BOTTOM MOUNTS
Amana ARB8057CSL REF - BOTTOM MOUNTS
Amana ARB8057CSR REF - BOTTOM MOUNTS
Amana ARB8057CW REF - BOTTOM MOUNTS
Amana ARB9058CB REF - BOTTOM MOUNTS
Amana ARB9058CS REF - BOTTOM MOUNTS
Amana ARB9058CW REF - BOTTOM MOUNTS
Amana ARB9059CS REF - BOTTOM MOUNTS
Amana ARC-1 RANGE- S/C S/I DDRAFT GAS
Amana ARC-100 RANGE- S/C S/I DDRAFT GAS
Amana ARC-100B RANGE- S/C S/I DDRAFT GAS
Amana ARC-1B RANGE- S/C S/I DDRAFT GAS
Amana ARC-2 RANGE- S/C S/I DDRAFT GAS
Amana ARC-2B RANGE- S/C S/I DDRAFT GAS
Amana ARC-506 RANGE- S/C S/I DDRAFT ELE
Amana ARC100B RANGE- S/C S/I DDRAFT ELE
Amana ARC100D RANGE- S/C S/I DDRAFT ELE
Amana ARC1B RANGE- S/C S/I DDRAFT ELE
Amana ARC502W RANGE- S/C S/I DDRAFT ELE
Amana ARC505 RANGE- S/C F/S ELE
Amana ARC505B RANGE- S/C S/I DDRAFT ELE
Amana ARC515 RANGE- S/C S/I DDRAFT ELE
Amana ARC515 RANGE- S/C S/I DDRAFT GAS
Amana ARC700E Range - S/c S/i Ddraft Ele
Amana ARC700E RANGE- S/C S/I DDRAFT ELE
Amana ARC700LL RANGE- S/C S/I DDRAFT ELE
Amana ARC700WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS800E RANGE- S/C S/I DDRAFT ELE
Amana ARDS800WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS801E RANGE- S/C S/I DDRAFT ELE
Amana ARDS801WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS802E RANGE- S/C S/I DDRAFT ELE
Amana ARDS802SS RANGE- S/C S/I DDRAFT ELE
Amana ARDS802WW RANGE- S/C S/I DDRAFT ELE
Amana ARE14 MISC / ACCESSORY
  #2 (permalink)
Old 12-16-2009, 03:21 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
If it is a defrost problem it usually shows up in the fresh food section first.
I am assuming you mean the food in the freezer.
This could be caused by a leaking door seal.
Check that the seals are not catching or curling over on the hinge side of the doors. If it is a light coating of grease/vaseline often solves this.
Take a 2 inch piece of paper or a dollar bill and place it between the seal and the frame then pull it out you should feel some resistance. Work your way around the doors to find a seal leak. Also check the seals for rips etc.
I could not find info on this unit so am assuming that the above refers to a mechanical defrost timer. If you rotated the cam a full 360 degrees and it did not go into a defrost cycle then you have a bad defrost timer.
No ice buildup.
Are you referring to the evaporator coils?
Which ones the condenser/compressor or the evaporator (freezer)?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer too cold, frost in freezer & fridge InAZ Refrigerator & Freezer Repair 4 02-05-2010 06:53 AM
Refrigerator not cold frost on food in freezer waltd15 Refrigerator & Freezer Repair 0 12-02-2009 02:29 PM
Frost Build-Up in freezer (refrig & freezer not as Cold as usual) boots1 Oven Repair (including Ranges and Cooktops) 1 01-18-2009 03:08 AM
Freezer cold, evaporator fan not working, frost build up in freezer heretolearn2 Refrigerator & Freezer Repair 3 05-28-2008 02:45 PM
Freezer has frost and cold/frig is not very cold DinATL Refrigerator & Freezer Repair 1 09-14-2007 07:38 PM
