Discuss
Upright Freezer
 in
Refrigerator & Freezer Repair
Gentlemen, Recently, I discovered that my freezer (20.6 cu. ft - upright) stopped working (partially thawed meat). I advanced the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Upright Freezer
  #1 (permalink)
Old 03-17-2008, 03:19 PM
Mik Mik is offline
Junior Member
Mik is on a distinguished road
Default Upright Freezer
Brand: Kenmore   Age: 5 - 10 years
Gentlemen,
Recently, I discovered that my freezer (20.6 cu. ft - upright) stopped working (partially thawed meat). I advanced the temp control knob from 4 to 6 and heard the compressor kick on. I then immediately dialed the temp control wheel back to 4.
The freezer continued to work for 2 additional days before it went back to being broke (partially frozen water bottles).
I realize the reason may be just about anything but is there anything I can trouble shoot to locate the culprit. I live in a remote area and service technicians are hard to locate.
Thx!
Mik
Ads By Google
  #2 (permalink)
Old 03-18-2008, 03:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Mik,
In order to provide most accurate advise we need the complete model number of the unit.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-18-2008, 03:12 PM
Mik Mik is offline
Junior Member
Default Mik's Kenmore Freezer issues
Gene,
Thanks for your email. WOW, this reply system seems cumbersome. I'm not sure if you'll get this nor am I sure if you will know whom it is from. Anyway, you asked for the model number of my 8 yo Kenmore freezer which is 253.9280213, Serial No. WB02122482. My issue is thus. Upon discovery that my meat was partially thawed in the upright, 20.3 cu. ft. freezer, I turned the temp control dial from the 4 position to the 6 position. Immediately the compressor kicked on so I dialed the temp. control back to No. 4. Things chugged along very well for approximately 2 days before the freezer gave up the ghost entirely. I'm trying to trouble shoot the problem as getting a tech. out to my remote location is challenging at worst. If there are similar folks reporting the same problem and there is a common remedy, I'd love to learn it.
Thank-you Gene,
Mik
  #4 (permalink)
Old 03-18-2008, 03:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Mik,
The first thing I would do is bypass the temperature control.
If the compressor will start then the problem is a bad temperature control.
- The part number for the temperature control is AP2113445
__________________
  #5 (permalink)
Old 03-18-2008, 03:39 PM
Mik Mik is offline
Junior Member
Default
Now ,why didn't I think of that - duh!
Guess that's why u get the big bucks!!!
Thx. Cross your fingers that's the issue.
I'll do what you suggest tonight and will let ya know the results either positive or negative.
Thanks again!
  #6 (permalink)
Old 03-20-2008, 02:01 PM
Mik Mik is offline
Junior Member
Default
Gene,
By-passed the temp control and compressor started. Therefore, I ordered the part you referenced via our last communication. Thx again.
Does it harm the freezer to sit the 4 days until the part arrives? Otherwise, I'll by-pass the switch and let the freezer run for a bit.
Mik
  #7 (permalink)
Old 03-20-2008, 03:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Mik,
Keep it off and let me know how it'll go.
__________________
  #8 (permalink)
Old 03-31-2008, 01:44 PM
Mik Mik is offline
Junior Member
Default
Gene,
New switch works. Freezer has been working fine for days now. I believe I got it licked thanks to your advice. thx again.
However, I forgot how the power leads hook up so i took a guess and figured it is ac and doesn't matter??? If one looks from the dial side I connected the blue lead to the left terminal.
Mik
  #9 (permalink)
Old 03-31-2008, 01:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Mik,
I'm glad you were able to fix it. Do not worry about wires - it does not matter.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Upright Freezer draco Refrigerator & Freezer Repair 0 10-23-2009 11:05 AM
upright freezer nana b Refrigerator & Freezer Repair 2 08-30-2009 12:34 PM
upright freezer BG Ratliff Refrigerator & Freezer Repair 1 08-25-2009 04:01 AM
Upright freezer ffredvann Refrigerator & Freezer Repair 1 10-08-2008 05:20 PM
Upright Freezer Help cpinke15 Refrigerator & Freezer Repair 1 11-21-2007 10:29 AM
