Ice maker stopped working years ago,so ive been buying bagged ice and dumping it in hopper. So ive decided to finally fix ice maker-
1.pulled solenoids and valves -cleaned screen in valves 2.made sure supply line wasnt frozen 3.tested module by jumping T and H , got ice maker to cycle ,and got led output code of 3 pulses
i dont have a bail arm switch,So i assume i need a new module I am about to pull old module and look for any problems
What problems do i look for in module,how do i test it,and could it be a thermostat problem?
i have found entire assembly on ******** for $44 dollars plus $14 shipping Thanks for any response
