Discuss
water intake valve installation question
 in
Refrigerator & Freezer Repair
My question is, I ordered the water intake valve no. GEH WR57X10012 for the above model. The original, before it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » water intake valve installation question
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-20-2007, 09:57 AM
deano49 deano49 is offline
Junior Member
deano49 is on a distinguished road
Default water intake valve installation question
Model Number: tfx22krcb aa   Brand: GE   Age: 1 - 5 years
The original, before it started leaking had the quick connect "push" tubes. The one sent to me now have the threaded style. How do I connect?
It was confirmed by online support adam/lon that this is the correct part.
I also need to know, since the original has been off for many months now which tube to go into which solenoid?
I await your reply.
thanks again
deano49
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-20-2007, 03:25 PM
Adam / APP Team Adam / APP Team is offline
Service Pro
APP Team
Adam / APP Team is on a distinguished road
Default
Dear deano49,
I have double checked the valve and come up with the same part number having threaded lines.
If your origonal valve has push in fittings you will have to make sure the tube is straight and use threaded nuts that you can pick up local or we can supply you with.
As far which of the two tubes go on which side you will notice there are two sizes. One is a 1/4" (smaller) and the other a 5/16" (larger). The smaller line provides water to the ice while the larger supplies water for the dispenser.
Please call me if you have any further questions. I will be glad to help
__________________
Need a part? Buy appliance parts from us. Fast delivery and great prices.
Thank you for supporting our free repair help forum.
  #3 (permalink)
Old 10-28-2007, 08:10 AM
superbravo superbravo is offline
Junior Member
superbravo is on a distinguished road
Default
I just replace the water inlet valve. Still not making Ice and about a glass of water is dispensing automatic every 10 minutes. I plug the red wire to the red and the white to the green of the valve. Did I plug the wire wrong?
  #4 (permalink)
Old 11-01-2007, 10:33 AM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default backwards
Sounds like you wired them backwards, if you push the water dispensing switch and water fills your ice maker cube mold then that will certainly confirm the solenoids are wired incorrectly...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
follow up to frigid rear drum question treefrog Washer Repair 0 08-19-2007 01:24 PM
Water inlet valve m/c Refrigerator & Freezer Repair 2 07-31-2007 10:34 PM
water valve wiring hotpoint/ge Cuch Washer Repair 2 07-24-2007 05:29 PM
water flow valve BRAND001 Washer Repair 0 07-23-2007 07:05 PM
Water inlet valve gentleben Refrigerator & Freezer Repair 1 07-19-2007 11:04 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
