Discuss
kenmore needs help? or does last owner?
 in
Refrigerator & Freezer Repair
Heloo, Im a proud owner of a beautiful refridge, side/side ice and water in door, it was in paper
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » kenmore needs help? or does last owner?
  #1 (permalink)
Old 03-17-2008, 02:10 PM
scooterdog69 scooterdog69 is offline
Junior Member
scooterdog69 is on a distinguished road
Thumbs up kenmore needs help? or does last owner?
Model Number: 5253401   Brand: Kenmore   Age: 5 - 10 years
Heloo, Im a proud owner of a beautiful refridge, side/side ice and water in door, it was in paper for free? I responded 2 miniutes later and got it . Was told I could have it, I got it home supposely not working, I removed the water line that was shoved in the bottom ( preventing fan from running) now it seems to be running fine?? Did I luck out or should I check other things before I junk my old one and I have to cut my upper cabinet out and raise up 2" just so it will fit? Did I get luckey? or am I missing something, or should I send thank-u note to the last owner?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-17-2008, 04:46 PM
Matt S Matt S is offline
Senior Expert
APP Volunteer
Matt S is on a distinguished road
Default
You may have lucked out. I would let it run for a few days to make sure it continues to cool and does not frost up. Sometimes refrigerator problems do not show up untill it has run a while (few days or so).
Matt
  #3 (permalink)
Old 03-19-2008, 05:38 PM
Junior Member
Default
NOT so luckey after all??/ The fridge gets cold but NOT enough after repair maan here (today) he thinks the coil has a hole in it, because fridge gets cold but not cold enough and after further investigation, the coil gets cold half way up and the other is still not frosted up , he sugested possible hole or leak? so he says probably not worth repairing? is he right? no self home repair available? If not, what a shame?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Business owner ibrahimdd Microwave Repair 2 11-15-2007 09:09 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
