Discuss
No water thru the door
 in
Refrigerator & Freezer Repair
GE double door refrigerator freezer --no water thru the door dispenser--valve ok--filter ok -- water pressure to the bottom
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » No water thru the door
  #1 (permalink)
Old 03-17-2008, 11:42 AM
pjzeke pjzeke is offline
Junior Member
pjzeke is on a distinguished road
Default No water thru the door
Model Number: GSS25KGMCCC   Brand: GE   Age: 5 - 10 years
GE double door refrigerator freezer --no water thru the door dispenser--valve ok--filter ok -- water pressure to the bottom of the door --ran a wire up door tube and hit a stop near the dispenser--is it possible tube is frozen--how hard is it to dissassemble freezer door
JC
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-17-2008, 09:24 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Taking apart the door is pretty serious job, especially the freezer door because of wires and water line inside.
The door has to be removed from the fridge first.
It's better to try to defrost the water line with a hair dryer.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice maker will not draw water but water in door works normally kg1okc Refrigerator & Freezer Repair 3 01-26-2008 03:57 PM
No water on door pjboutin Refrigerator & Freezer Repair 5 12-16-2007 03:33 PM
Water leaking under door...need to know how to remove door & replace seal edbolliera Dishwasher Repair 1 11-27-2007 04:42 AM
door water Frigidaire Deanrl Refrigerator & Freezer Repair 5 11-21-2007 02:42 PM
water dispensing from door on it's own jenofflorida@aol.com Refrigerator & Freezer Repair 0 08-13-2007 01:20 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
