Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   Broke water line for side by side Refrigerator (http://forum.appliancepartspros.com/refrigerator-freezer-repair/63623-broke-water-line-side-side-refrigerator.html)
mrshakim 12-11-2009 04:53 PM
How do you repair a broken water line on a side by side freezer door?
jeffrey_benjamin 12-11-2009 07:01 PM
Quote:
Remove the door liner to get to the tubing:)
mrshakim 12-12-2009 09:56 AM
Quote:
How do you remove the door liner?
jeffrey_benjamin 12-12-2009 01:51 PM
[quote=mrshakim;158123]How do you remove the door liner?[/quotewhat is the model # of ur refrigerator
phillcan5 12-12-2009 02:07 PM
Broken water line
Mine broke and it was easier than i expected the plastic tip broke off where it comes out the dispenser.So what i did is exposed enough hose to cut out the whole plastic piece.Then i found something to join the two hoses together(old to new)snugly then i pulled on the old hose at the bottom of the door to feed the new one thru piece of cake then you connect up the waterline at bottom of door and reattach back in the dispenser.
mrshakim 12-17-2009 06:54 AM
Thanks! It worked like a charm.
