Discuss
Ge Side by side
 in
Refrigerator & Freezer Repair
I have looked at the posts. Mine is a little different. My crisper is turning into a freezer which also
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ge Side by side
  #1 (permalink)
Old 12-08-2009, 05:59 AM
Junior Member
Charles Neighbors is on a distinguished road
Default Ge Side by side
Brand: GE   Age: 1 - 5 years
My crisper is turning into a freezer which also causes the water line to freeze. Top of the fridge is warmer than the bottom. On the freezer side the bottom is cold but the ice maker is hot, there is water in the unit but it will not freeze. Help
Ads By Google
  #2 (permalink)
Old 12-08-2009, 06:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the refrigerator?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-10-2009, 05:44 AM
Junior Member
Default Ge Refrigerator
Gene,
The Model number is GSL25JFPH BS
  #4 (permalink)
Old 12-10-2009, 02:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Turn the ice maker off or unplug its wire harness and watch the refrigerator for a few hours. Put more attention on the cold air flow through the damper control (#426 on the diagram). Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric GSL25JFPHBS Refrigerator | AppliancePartsPros.com
__________________
  #5 (permalink)
Old 12-10-2009, 03:15 PM
Junior Member
jaxcarlson is on a distinguished road
Default
I am having pretty much the same issue as Charles. My bins in the fridge side are freezing, and the freezer is not freezing on the top part. I took the plate out in the back of the freezer and saw the coils are frozen over in the middle third, but not so much frozen over in the top and bottom thirds. I have a GE side by side, model GSS25TSRE. Any tips would be appreciated, and I will unplus the icemaker assembly like you suggest and look at the damper control.
  #6 (permalink)
Old 12-10-2009, 04:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
You refrigerator has a different design compared to the one owned by Charles. The problem you described has nothing to do with the ice maker because yours is not hot. Watch the damper control and post the results.
Here are the breakdown diagrams and Replacement parts for General Electric GSS25TSRESS Refrigerator | AppliancePartsPros.com
__________________
  #7 (permalink)
Old 12-10-2009, 04:45 PM
Junior Member
Default
After doing some searching it appears it may be the thermistor or the thermostat. Is there a way to check the thermistors, or should I replace them since they are relatively cheap anyway (compared to a service call)?
  #8 (permalink)
Old 12-10-2009, 04:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The best way is to diagnose exact problem and then fix it. Guessing is not the way I'd like.
So far the problem with your refrigerator can be a bad damper control or a faulty defrost system.
__________________
  #9 (permalink)
Old 12-14-2009, 06:19 AM
Junior Member
Unhappy
Gene,
I checked the Fridge several times this weekend, with the ice maker off.
When the Fridge door is closed (holding the button) the Damper stays open all the time. When the fridge is open it closes. When I left the damper unpluged the water despenser works after is thaws out. Tried plugging in the damper and turning on the power to the ice maker, still no ice and the water line froze back up.
  #10 (permalink)
Old 12-14-2009, 06:20 AM
Junior Member
Default
Gene,
P.S. the air flow going from the damper to the Frezzer did not seem to fast.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
side by side refrigerator - fridge side freezing food, water coming out of freezer bomb Refrigerator & Freezer Repair 8 08-30-2011 01:58 PM
whirpool side by side lights don't work in refrigerator side and also digital temp dvite Refrigerator & Freezer Repair 5 02-02-2011 04:47 PM
Side by Side leaking from top inside fridge side jns992001 Refrigerator & Freezer Repair 0 01-16-2010 09:17 AM
GE side by side refrig tfh22prsm ww leaking from bottom, no longer cold either side thomashaskins Refrigerator & Freezer Repair 3 09-13-2009 07:01 PM
Maytag side by side freezing FF side, stumped gobucks50 Refrigerator & Freezer Repair 0 08-26-2009 02:16 PM
