AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
JennAir Refrig Door Controls - Ice Dispenser Door Solenoid Valve
My door ice disperser solenoid will not open.
The problem started with a stuck solenoid valve. I replaced the control board and the complete door fountain kit (order no. 917501).
Now the water and ice will work but the solenoid valve that opens the fountain door will not open. The ice auger will run, but only builds up in the door chute.
Could I have either a bad control board or solenoid? Both were just replaced. Note that the water controls are all okey, and the ice auger / crusher are both okay. Only the door will not open. The ice just backs up in the door chute.
Thanks in advance
Kevin
