Discuss
ice maker quit working
 in
Refrigerator & Freezer Repair
My ice maker just quit working out on the blue. The refer has ice and water in the door and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ice maker quit working
  #1 (permalink)
Old 03-13-2008, 04:06 PM
turn543 turn543 is offline
Junior Member
turn543 is on a distinguished road
Default ice maker quit working
Model Number: 106.53552201   Brand: Kenmore   Age: 5 - 10 years
My ice maker just quit working out on the blue. The refer has ice and water in the door and the water works fine. Could you please assist me? Thanks, Scott
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-14-2008, 03:12 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Scott,
The first thing I would do: check if the shut off arm is in down position.
Then remove the head cover and check for 120V between the "L" & "N" test points.
If there is 120V - short the "T" & "H" with an insulated piece of wire to run the motor.
If the motor does not run - replace the module assembly or the whole ice maker.
If the motor runs - replace the thermostat.
Leave the jumper wire in for a half of a revolution and remove it. The water valve should be energized in the last half of the revolution.
Post your findings and I will provide the right part number(s).
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-25-2008, 01:46 PM
Junior Member
Default
I found the water in the supply line in the top of the freezer to be froze. After thawing out wvwerything worked great. Thanks.
I did break the swing door on the inside left of the fridge that closes when the freezer door is closed, if you could help me with the part # that I can order. Thanks again.
  #4 (permalink)
Old 03-25-2008, 02:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Good job!
The part number for the flipper is AP3037562
The flipper
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE ice maker quit working dottiedrew Refrigerator & Freezer Repair 1 03-01-2008 10:33 AM
Ice Maker Quit Working JAMJR Refrigerator & Freezer Repair 0 02-28-2008 08:06 AM
ice maker quit making ice amandamitchem Refrigerator & Freezer Repair 2 01-03-2008 02:58 PM
Ice Maker quit working tips Refrigerator & Freezer Repair 0 10-17-2007 04:16 PM
New Dishwasher quit working Waiting Dishwasher Repair 1 09-18-2007 08:49 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
