Discuss
freezer door on Amana refrigerator
 in
Refrigerator & Freezer Repair
The freezer door won't stay closed. The freezer is beneath the fridge and every time anyone closes the fridge
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » freezer door on Amana refrigerator
  #1 (permalink)
Old 03-12-2008, 02:59 PM
NancyHarvey NancyHarvey is offline
Junior Member
NancyHarvey is on a distinguished road
Default freezer door on Amana refrigerator
Model Number: It is an Amanna 20 Energy Saver Fridge   Brand: Amana   Age: 5 - 10 years
The freezer door won't stay closed. The freezer is beneath the fridge and every time anyone closes the fridge door, the freezer door pops open. I've cleaned around the edge of the gasket - to no avail. Is it a magnet that holds it closed? Or some kind of vacuum seal? Do I need to replace the gasket? YIKES. How?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-13-2008, 12:53 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Nancy,
Check the door frame. It should be clean, without paint bubbles and rust.
Check the door gasket for any damages.
Check the bottom door hinge for any worn parts.
For more accurate advise I need the complete model number of the fridge.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-15-2008, 04:22 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If the old gasket will not firmly grip a dollar bill, replace the gasket. If the gasket is not firm all the way around, you may have to pull the door off, loosen the screws, and re-align.
__________________
  #4 (permalink)
Old 03-15-2008, 06:14 AM
Matt S Matt S is offline
Senior Expert
APP Volunteer
Matt S is on a distinguished road
Default
The door does not need to be removed to be realigned. Realignment is accomplished by accessing the screws behind the door gasket (fold gasket back).
Odds are you do not need a new gasket. In fact, the new gasket will take a while to take on the shape of the refrigerator housing and will, therefore, not seal as well at the beginning.
Gene made mention of the lower door hinge. That is a good place to start looking for the problem. If that hinge is bad, the door will sag and hit the bottom of the frame (plastic liner on the bottom of the freezer). Look for scuffs on the plastic where the bottom of the door closes. If the door is hitting the plastic liner of the freezer at the bottom, that is your problem and would normally indicate a bad hinge. Not to muddy the waters, but, I have even seen refrigerators with cabinets that are tweaked (misaligned from one corner of cabinet to the other corner) from not sitting evenly on the floor for years. This will make the freezer door hit the bottom of the freezer. This is rare, though.
One more thing is to check the gasket at the hinge side. Make sure the gasket is closing well and not bunching in that area. That will give you this symptom as well.
Last thing to check is if there is anything hitting the door on the inside. This is very easy to overlook and very common.
As you can tell, there are alot of possibilities here.
Matt
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Refrigerator drain freeze problem Scottrse1 Refrigerator & Freezer Repair 7 09-05-2008 06:34 PM
Refrigerator/Freezer has liquid leaking inside freezer and frig terrib Refrigerator & Freezer Repair 0 12-25-2007 11:15 PM
Amana bottom freezer refrigerator MAL Refrigerator & Freezer Repair 1 08-18-2007 06:47 PM
Amana Side by Side Refrigerator Freezer MFG. P1317202WE josephbowles@earthlink.ne Refrigerator & Freezer Repair 0 08-10-2007 06:38 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
