Discuss
Water elaking into botom of refrigerator
 in
Refrigerator & Freezer Repair
I have water accumulating under the vegetable crisper drawers. This is most likely a clogged drain line or cup. Can
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water elaking into botom of refrigerator
  #1 (permalink)
Old 03-11-2008, 11:51 PM
FoxJohnSix FoxJohnSix is offline
Junior Member
FoxJohnSix is on a distinguished road
Default Water elaking into botom of refrigerator
Model Number: 85188   Brand: Amana   Age: More than 10 years
This is most likely a clogged drain line or cup. Can anyone tell me if this will need a technician to repair or can I fix it? I understand some refridgerator/freezers have some enclosed plumbing. But then it may be a simple clean/repair job.
Any guides, images, or posts on how to fix this problem on an Amana refridgerator/top freezer model #85188?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-12-2008, 05:47 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to provide most accurate advise I need the complete model number of the fridge. The model number you posted is incorrect.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-12-2008, 09:49 PM
Junior Member
Default Water leaking and pooling under vegetable drawers.
I checked the model number again and here is everything listed inside the
fridge:
Model #85188
MFG NO.P1117108WL
S/N 9112129959
Design Pressure 235HS & 140LS
We have had this refridgerator for almost.... 16 years.
I know it is probably the freezer draining that is blocked or a drain cup clogged, but I am not sure how to access these areas.
Thanks for your help.
John
  #4 (permalink)
Old 03-13-2008, 02:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi John,
Remove the back panel in the freezer. The drain is located under the evaporator coil. Most likely it's clogged and/or frozen.
Defrost it, using a hair dryer. Run some hot water through the drain to make sure it's open.
Remove the cover on the back of the fridge and check the other end of the drain hose for a clog.
It's a good time to clean the condenser coil too.
__________________
  #5 (permalink)
Old 03-14-2008, 07:28 AM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hi John,
Thanks Gene. I take it yopu mean the back panel INSIDE the freezer box? Or the backside of the whole unit?
  #6 (permalink)
Old 03-14-2008, 10:17 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Both of them, but inside the freezer first. The drain is there.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water in the refrigerator jacota Refrigerator & Freezer Repair 1 08-30-2008 07:57 PM
water leaking into refrigerator Rebekah Durham Refrigerator & Freezer Repair 3 08-11-2008 12:51 PM
refrigerator Ice & water dispenser HELP nash Refrigerator & Freezer Repair 0 01-26-2008 09:04 AM
refrigerator : water on tray joshzz Refrigerator & Freezer Repair 1 12-19-2007 02:16 PM
water inside refrigerator edbeck Refrigerator & Freezer Repair 1 09-25-2007 11:13 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
