jimmielindsey@comcast.net
#1 Posted : Friday, December 4, 2009 8:22:53 AM(UTC)
Once I have replaced this device is their anything else that I need to look for? I found it burned up because the frig was not cooling on the frig side not the freezer side.
#2 Posted : Friday, December 4, 2009 12:37:09 PM(UTC)
Here is a tech sheet
http://www.servicematters.com/d...0Sheet%20-%202255373.pdf
Not a bad idea to check the compressor windings before replacing it as bad/shorted windings will just burn up the new starter.
Be sure to check the winding connectors to the compressor's case. Usually there is a ground strap or you may have to scrape off some paint.
Below is a site on how to check it
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
New Starting Device with Run Capacitor (Refrigerator & Freezer Repair)
by d13peters 9/13/2016 6:36:21 AM(UTC)
compressor/starting device (Refrigerator & Freezer Repair)
by randybpatrick 6/9/2013 4:36:29 PM(UTC)
Steps to install part AP3885081 (8201786) Compressor starting device kit (Refrigerator & Freezer Repair)
by yxie881 1/29/2013 7:50:07 PM(UTC)
Compressor's Starting Device replacement (Refrigerator & Freezer Repair)
by Marton 7/4/2011 10:00:02 AM(UTC)
Please Help! Starting Device to Compressor started on FIRE! (Refrigerator & Freezer Repair)
by clarkrm1974@yahoo.com 12/23/2010 7:09:03 PM(UTC)
Installing New Starting device kit, compressor (Refrigerator & Freezer Repair)
by Mike717 4/13/2010 1:43:10 PM(UTC)
PTC Starting Devices (Refrigerator & Freezer Repair)
by bluefitness 12/31/2009 8:54:48 PM(UTC)
? Part that plugs into starting device that connects to compressor (Refrigerator & Freezer Repair)
by rthoben 3/21/2009 12:41:31 PM(UTC)
