Discuss
freezer defrosting
 in
Refrigerator & Freezer Repair
The freezer side of this side by side seems to be defrosting and I cannot hear the motor cycling on
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » freezer defrosting
  #1 (permalink)
Old 03-10-2008, 09:07 PM
gefridge gefridge is offline
Junior Member
gefridge is on a distinguished road
Default freezer defrosting
Model Number: gss25tgmfww   Brand: GE   Age: 1 - 5 years
hear the motor cycling on and off, The fridge side seems ok but it is too early to tell.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-11-2008, 06:24 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the rear cover and check if the compressor is running.
If not, remove the cover for the main control board (on the back of the fridge) and inspect the control board for any burned spots.
Post your findings.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-11-2008, 08:33 PM
Junior Member
I can't really hear anything from the compressor, it is warm to the touch
and the fan next to it is blowing. Also the circuit board has no signs of
burning.
  #4 (permalink)
Old 03-12-2008, 12:48 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If the condenser fan motor (next to the compressor) is running while the compressor is warm to the touch but not vibrating (not running) it could be a bad compressor, a bad compressor start device or a bad control board.
Check for 120VAC at the J7-9 connector (orange wire) to the terminal J8 (black wire) on the main control board.
If there is no 120VAC - replace the main control board.
If there is 120VAC then check the wires to the compressor.
If there is nothing wrong then the compressor is bad and has to be replaced. This job has to be done by a certified technician.
- The part number for the main control board is AP3950129
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
defrosting problem svtblkfrdlightng Refrigerator & Freezer Repair 0 02-26-2008 09:56 AM
Freezer not defrosting vinnier Refrigerator & Freezer Repair 0 02-03-2008 09:09 AM
Refrigerator/Freezer has liquid leaking inside freezer and frig terrib Refrigerator & Freezer Repair 0 12-25-2007 11:15 PM
Self Defrosting Freezer DEMETRICK Refrigerator & Freezer Repair 1 11-09-2007 04:00 PM
Amana BX21VL not defrosting biggxj Refrigerator & Freezer Repair 0 10-07-2007 05:56 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
