Discuss
too much water for ice-maker
 in
Refrigerator & Freezer Repair
Too much water in icemaker. What determines the water level in icemaker? I have water coming out of the ice
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » too much water for ice-maker
  #1 (permalink)
Old 11-30-2009, 12:42 PM
Junior Member
vadavidson is on a distinguished road
Default too much water for ice-maker
Model Number: ED22DQXAB00   Brand: Whirlpool   Age: More than 10 years
What determines the water level in icemaker? I have water coming out of the ice despenser after each cycle and the bottom of bucket is frozen solid, I won't even try to use the auger, it is in solid ice. I've turned the valve down on water line so flow amount is restricted to minimum and it still fills the ice maker tray over. Is there a water level sensor??
Thanks, Vern
Ads By Google
Related Models
Whirlpool ED22DQXAB00
Whirlpool ED22DQXAB10
Whirlpool ED22DQXAB11
Whirlpool ED22DQXAN00
Whirlpool ED22DQXAN10
Whirlpool ED22DQXAN11
Whirlpool ED22DQXAW00
Whirlpool ED22DQXAW10
Whirlpool ED22DQXAW11
Whirlpool ED22DQXBB00
Whirlpool ED22DQXBB01
Whirlpool ED22DQXBN00
Whirlpool ED22DQXBN01
Whirlpool ED22DQXBW00
Whirlpool ED22DQXBW01
Whirlpool ED22DQXDB00
Whirlpool ED22DQXDB01
Whirlpool ED22DQXDN00
Whirlpool ED22DQXDN01
Whirlpool ED22DQXDW00
Whirlpool ED22DQXDW01
Whirlpool ED22DQXEB01
Whirlpool ED22DQXEB03
Whirlpool ED22DQXEB04
Whirlpool ED22DQXEN01
Whirlpool ED22DQXEN03
Whirlpool ED22DQXEN04
Whirlpool ED22DQXEW00
Whirlpool ED22DQXEW01
Whirlpool ED22DQXEW03
Whirlpool ED22DQXEW04
Whirlpool ED22DQXXN00
Whirlpool ED22DQXXN01
Whirlpool ED22DSXDB00
Whirlpool ED22DSXDB01
Whirlpool ED22DSXDB02
Whirlpool ED22DSXDN00
Whirlpool ED22DSXDN01
Whirlpool ED22DSXDN02
Whirlpool ED22DSXDW00
Whirlpool ED22DSXDW01
Whirlpool ED22DSXDW02
Whirlpool ED22DSXEB00
Whirlpool ED22DSXEB01
Whirlpool ED22DSXEN00
Whirlpool ED22DSXEN01
Whirlpool ED22DSXEW00
Whirlpool ED22DSXEW01
Whirlpool ED22DWXTF00
Whirlpool ED22DWXTF01
Whirlpool ED22DWXTF02
Whirlpool ED22DWXTF03
Whirlpool ED22DWXTF04
Whirlpool ED22DWXTF05
Whirlpool ED22DWXTG00
Whirlpool ED22DWXTG01
Whirlpool ED22DWXTG02
Whirlpool ED22DWXTG03
Whirlpool ED22DWXTG04
Whirlpool ED22DWXTG05
Whirlpool ED22DWXTM00
Whirlpool ED22DWXTM01
Whirlpool ED22DWXTM02
Whirlpool ED22DWXTM03
Whirlpool ED22DWXTM04
Whirlpool ED22DWXTM05
Whirlpool ED22DWXTN00
Whirlpool ED22DWXTN01
Whirlpool ED22DWXTN02
Whirlpool ED22DWXTN03
Whirlpool ED22DWXTN04
Whirlpool ED22DWXTN05
Whirlpool ED22DWXTW00
Whirlpool ED22DWXTW01
Whirlpool ED22DWXTW02
Whirlpool ED22DWXTW03
Whirlpool ED22DWXTW04
Whirlpool ED22DWXTW05
Whirlpool ED22DWXWN00
Whirlpool ED22DWXWW00
Whirlpool ED22EKXPWR0
Whirlpool ED22EMXPWR0
Whirlpool ED22EMXPWR2
Whirlpool ED22F134QN0
Whirlpool ED22GWXFN00
Whirlpool ED22GWXFN01
Whirlpool ED22GWXFN02
Whirlpool ED22GWXFN03
Whirlpool ED22GWXFN04
Whirlpool ED22GWXFN05
Whirlpool ED22GWXFT04
Whirlpool ED22GWXFT05
Whirlpool ED22GWXFW00
Whirlpool ED22GWXFW01
Whirlpool ED22GWXFW02
Whirlpool ED22GWXFW03
Whirlpool ED22GWXFW04
Whirlpool ED22GWXFW05
Whirlpool ED22GWXWN10
Whirlpool ED22GWXWW00
Whirlpool ED22GWXWW10
Whirlpool ED22GWXXN00
Whirlpool ED22GWXXN01
Whirlpool ED22GWXXW00
Whirlpool ED22GWXXW01
Whirlpool ED22HDXBB00
Whirlpool ED22HDXBN00
Whirlpool ED22HDXBW00
Whirlpool ED22HPXBN00
Whirlpool ED22HPXBN01
Whirlpool ED22HPXBW00
Whirlpool ED22HPXBW01
Whirlpool ED22LFXGB00
Whirlpool ED22LFXGN00
Whirlpool ED22LFXGT00
Whirlpool ED22LFXGW00
Whirlpool ED22LFXHB00
Whirlpool ED22LFXHB01
Whirlpool ED22LFXHB02
Whirlpool ED22LFXHB03
  #2 (permalink)
Old 11-30-2009, 08:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Vern,
Remove the ice maker front cover. On the right side of the head you'll see the water level adjustment screw. Turn it CW for 1/2 turn and check the water level. You can do it one more time if needed. Further adjustment could damage the module.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-01-2009, 07:31 AM
Junior Member
Default soo much water for icemaker
Thanks, well I suppose my icemaker may be kaput. I did as you said, I turned the little adjustment on the right side a half turn clockwise and now it is worse, it lets about a half pint of water run each cycle, way too much water. Thanks for the help, Vern.
  #4 (permalink)
Old 12-01-2009, 01:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Locate the water inlet valve on the back of the refrigerator. The solenoid where the 1/4" tube is connected to is for the ice maker. Disconnect the wires from the solenoid and check for 120VAC between them while the ice maker calls for water.
If the power is "ON" for more than 7 seconds, replace the ice maker.
If there is nothing wrong with the power, but water is still coming into the ice maker, replace the water inlet valve.
- The water inlet valve Part number: AP3085178
- The ice maker Part number: AP2984633
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ED22DQXAB00 | AppliancePartsPros.com
__________________
  #5 (permalink)
Old 12-01-2009, 02:15 PM
Junior Member
Ok, Gene. I can do that, 7 seconds. Thanks.
I looked at all that, but I didn't know the time required.
I'm sure the selenoid is ok, it doesn't let water through
either side -unless the icemaker asks
for it or the drinking water valve is pressed.
Thanks again, Vern.
  #6 (permalink)
Old 12-24-2009, 04:01 PM
Junior Member
Default too much water in icemaker
Gene, thanks. My icemaker was kaput, as you said, turning the little timing device didn't make any difference, it appears that even the heat element didn't cycle on, the ice wouldn't turn loose from the trays, causing the water to overflow over the ice.
A new icemaker and also the inlet valve was istalled and now I have peace and harmony in the house. (And ice without water on the floor and ice forming on the ice cream cartons on the shelves below) The parts aren't cheap, but we had a Christmas club account to draw from. Thanks, Vern.
  #7 (permalink)
Old 12-25-2009, 10:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome, Vern.
I'm glad you were able to fix it.
Happy Holidays!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
New ice maker installed but no water running to ice maker corona32guiness Refrigerator & Freezer Repair 0 01-06-2010 05:14 PM
Ice Maker water is dispensing into the bin instead of into the cube maker jghani Refrigerator & Freezer Repair 0 09-12-2009 10:27 AM
Ice Maker water is dispensing into the bin instead of into the cube maker jghani Refrigerator & Freezer Repair 0 09-12-2009 10:20 AM
water not getting to hose from pump but water dispencer works not ice maker sharbrat Refrigerator & Freezer Repair 0 07-29-2009 10:38 AM
Replaced Ice Maker and noid and still no water to ice maker darrewhite Refrigerator & Freezer Repair 0 05-17-2009 06:34 AM
