| » Ice Dispenser Agitator Motor |
Model Number: KSRG25FKSS15 Brand: Kitchen Aid Age: 1 - 5 years
The agitator in the ice cube container will not rotate when I despress the lever to get ice, thus ice is not dispenced. The water comes out fine. The light comes on, the delay closes the chute cover. I cannot turn the hex shaft with a socket wrench. I am assuming it is the motor 3776020. I have had the front off-the plastic cover that covers the controls, can see the levers-if I remove the levers, can I remove the next enclosure and get to the motor? Thanks.
The instructions are attached to the reply.
- The motor Part number: AP3776020 Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRG25FKSS15 Refrigerator | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Gene-thanks for your quick reply--my question is how to get to the motor. I have the diagram and part number but want to know if I access from the front of the door or do I need to take the inner liner of the door out? Thanks for what you do. Harold
Quote:
__________________
First off, I am impressed with the response and the links that helped me get the motor out and understand the circuitry. So, I have the motor out, the drive for the shaft will not turn by hand, I have put 110 AC V to correct terminals, no movement and I have jumped the two that come from the cube switch, still no movement. My problem---I cannot get 115 V DC on either of the wire harness contacts from the cube and crushed controls, beyond that I do not get 115 V DC on either of the terminals in the back of the control panel--for either cube or crushed. I think that I am over my head. Is there a way I can run the motor on a bench or do I need a DC 115V Power Supply to do that? Again, I am impressed with this site, Thanks again for the help. Harold
Harold,
Sounds like the motor is bad. Also, looks like the dispenser electronics is bad as well due to the dispenser has built in inverter which converts the AC voltage to the DC voltage and your test shows missing DC voltage. - The dispenser front cover assembly Part number: AP3135525 Gene.
__________________
Thanks for all of your help--I had the motor on the workbench, removed and found water-----thought maybe it was froze up. Wow, it works. Without your help I would not have had it removed. Great service, thanks again. Harold
You are welcome, Harold. I'm glad you were able to fix it with no cost to you.
__________________
| Display Modes | |
| agitator doesn't spin, motor works, couplings are not broken | bobcosta | Washer Repair | 0 | 03-01-2009 10:41 AM |
| Ice dispenser motor not working | fear74 | Refrigerator & Freezer Repair | 0 | 02-26-2009 10:36 AM |
| how to replace ice dispenser motor | 1954bigd | Refrigerator & Freezer Repair | 1 | 01-13-2009 02:57 PM |
| motor on ice maker dispenser | deepriver | Refrigerator & Freezer Repair | 3 | 04-18-2008 04:09 AM |
| Motor runs but agitator does not | rons45cal | Washer Repair | 2 | 03-11-2008 04:14 PM |
