Discuss
Intermittent freezer problem
 in
Refrigerator & Freezer Repair
I've been encountering this intermittent problem in the past. That is, the freezer stops producing the ice. The 'band
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Intermittent freezer problem
  #1 (permalink)
Old 03-08-2008, 10:59 AM
DIYwannabee DIYwannabee is offline
Junior Member
DIYwannabee is on a distinguished road
Default Intermittent freezer problem
Model Number: KSRS251KSS03   Brand: Kitchen Aid   Age: 1 - 5 years
I've been encountering this intermittent problem in the past. That is, the freezer stops producing the ice. The 'band aid' solution that have worked in the past is just to reset the thermostat. That is to put it off then put it back. You'd know it starts to work because you can hear the compressor starts. This same situation happened often last summer. Maybe 4 times or even more. Every time I have to reset I have to put it into a higher position. The last time it happened was about 2 days ago when it was already at position 4. This time it did not work immediately after resetting that I have to unplug the refrigerator then reset the thermostat. I suspect the slide thermostat is defective. If it is, how would I know that it is indeed the problem. Then how would I replace it?
Any help would be much appreciated.
Thanking you in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer icing problem carlos p Refrigerator & Freezer Repair 3 06-26-2008 12:20 AM
freezer icing problem billinaz29 Refrigerator & Freezer Repair 4 04-07-2008 04:44 PM
Freezer gasket problem Timothy Wagner\ Refrigerator & Freezer Repair 0 10-08-2007 11:14 AM
freezer/refrigeratornot cooling, motor running with clicking sound intermittent counterbob20 Refrigerator & Freezer Repair 2 10-07-2007 01:23 PM
Fridge not cold, freezer fine: fan problem? eyanyo Refrigerator & Freezer Repair 1 08-27-2007 11:00 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
