like the compressor motor itself. Is this so and can it be lubricated? If it is in the compressor there is nothing you can do about it as this is a sealed system. If not - then what is it and what should I do? You have to locate the squeak. Could be something is rubbing on the frame when the compressor starts vibrating. Also could be the compressor fan or the evaporator fan both usually start up with the compressor. |
THIS FORUM IS DEAD!!!!!!! |
