Discuss
Amana side by side freezer problem
 in
Refrigerator & Freezer Repair
The refrigerator part of my unit seems to be cooling (maybe not 100%, but cooling adequately), but the freezer is
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana side by side freezer problem
  #1 (permalink)
Old 11-23-2009, 04:44 PM
Junior Member
dawgpound818 is on a distinguished road
Default Amana side by side freezer problem
Model Number: SXD25S2W   Brand: Amana   Age: More than 10 years
The refrigerator part of my unit seems to be cooling (maybe not 100%, but cooling adequately), but the freezer is not cooling. The unit is on and running, thermostat controls are in their normal place. It doesn't seem that the fan is blowing any chilled air into the freezer and it has been like this for 3 days. Any help or ideas are greatly appreciated.
Ads By Google
Related Models
Amana SXD25S2W Ref - SXS/I&W
Amana SXD26VE Ref - SXS/I&W
Amana SXD26VL Ref - SXS/I&W
Amana SXD26VW Ref - SXS/I&W
Amana SXD27NE Ref - SXS/I&W
Amana SXD27NL Ref - SXS/I&W
Amana SXD27NW Ref - SXS/I&W
Amana SXD27Q2E Ref - SXS/I&W
Amana SXD27Q2L Ref - SXS/I&W
Amana SXD27Q2W Ref - SXS/I&W
Amana SXD27TE Ref - SXS/I&W
Amana SXD27TL Ref - SXS/I&W
Amana SXD27TW Ref - SXS/I&W
Amana SXD322L Ref - SXS/I&W
Amana SXD322S2L Ref - SXS/I&W
Amana SXD322S2W Ref - SXS/I&W
Amana SXD322W Ref - SXS/I&W
Amana SXD520NW Ref - SXS/I&W
Amana SXD520SL Ref - SXS/I&W
Amana SXD520SW Ref - SXS/I&W
Amana SXD520TE Ref - SXS/I&W
Amana SXD520TW Ref - SXS/I&W
Amana SXD522VE Ref - SXS/I&W
Amana SXD522VW Ref - SXS/I&W
Amana SXD524VE Ref - SXS/I&W
Amana SXD524VW Ref - SXS/I&W
Amana SXDE25J Ref - SXS/I&W
Amana SXDE25JB Ref - SXS/I&W
Amana SXDE25JP Ref - SXS/I&W
Amana SXDE27NE Ref - SXS/I&W
Amana SXDE27NL Ref - SXS/I&W
Amana SXDE27NPE Ref - SXS/I&W
Amana SXDE27NPL Ref - SXS/I&W
Amana SXDE27NPW Ref - SXS/I&W
Amana SXDE27NW Ref - SXS/I&W
Amana SXDE27QE Ref - SXS/I&W
Amana SXDE27QL Ref - SXS/I&W
Amana SXDE27QW Ref - SXS/I&W
Amana SXDE522K Ref - SXS/I&W
Amana SXDE522M Ref - SXS/I&W
Amana SXDE526K Ref - SXS/I&W
Amana SXDE526M Ref - SXS/I&W
Amana SXDE528MW Ref - SXS/I&W
Amana SXDT22H Ref - SXS/I&W
Amana SXDT25H Ref - SXS/I&W
Amana SXDT522J Ref - SXS/I&W
Amana SXDT522K Ref - SXS/I&W
Amana SXDT522M Ref - SXS/I&W
Amana SXDT526J Ref - SXS/I&W
Whirlpool SXF300W0
Whirlpool SXF300W1
Whirlpool SXF300W2
Whirlpool SXF300W3
Whirlpool SXF300W4
Whirlpool SXF325W0
Whirlpool SXF325W1
Whirlpool SXF325W2
Whirlpool SXF330W0
Whirlpool SXF330W1
Whirlpool SXF350W0
Whirlpool SXF400W0
Whirlpool SXF400W1
Whirlpool SXF400W2
Whirlpool SXF400W3
Whirlpool SXF400W4
Whirlpool SXF430W0
Whirlpool SXF440W0
Whirlpool SXF440W1
Whirlpool SXF450W0
Whirlpool SXF500W0
Whirlpool SXF500W1
Whirlpool SXF500W2
Whirlpool SXF500W3
Whirlpool SXF500W4
Whirlpool SXF500W5
Whirlpool SXF530W0
Whirlpool SXF530W1
Whirlpool SXF530W2
Whirlpool SXF600W0
Whirlpool SXF600W1
Whirlpool SXF600W2
Whirlpool SXF600W3
Whirlpool SXF600W4
Whirlpool SXF600W5
Amana SXI20J Ref - SXS/I&W
Amana SXI20NE Ref - SXS/I&W
Amana SXI20NL Ref - SXS/I&W
Amana SXI20NW Ref - SXS/I&W
Amana SXI25SE Ref - SXS/I&W
Amana SXI25SL Ref - SXS/I&W
  #2 (permalink)
Old 11-24-2009, 05:52 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for SXD25S2W models | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/maytag...s/T13014R1.pdf
You have this backwards, it is the freezer/evaporator fan that pushes cold air from the freezer into the fresh food section.
Check that the compressor is running. It should be warm and you should be able to feel it vibrating.
If it is running then pull the cover in the freezer so you can see the evaporator coils.
If they are heavily iced/frosted over you have a defrost problem.
It will be one of 3 things.
The defrost timer Item 29 in Section 13. Rotate the timer cam till the fans and compressor go off, you are now in a defrost cycle. Check to see if the defost heating element comes on. Be careful do not burn your fingers.
If it does come on replace the timer.
If it does not come on check the following.
The defrost heater. Remove the wire to one side of it and check it with a meter usually around 20 ohms.
The defrost thermostat. Remove one wire from it and check it with a meter. Should be 0 ohms when frozen. Note it opens just above freezing so it must be frozen when checking.
If both the above are OK then you either have a broken wire or the contacts in the timer are toast.
Here are a couple good sites with troubleshooting help
http://www.applianceaid.com/frig.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
__________________
  #3 (permalink)
Old 11-24-2009, 06:44 AM
Junior Member
Default Update
OK, sorry for my ignorance. I'm mechanically inclined, but this is my first go at repairing a refrigerator. I turned the defrost timer and it does cycle the compressor on and off. I removed the inside lower (evaporator coils, etc) cover from the freezer to inspect the evaporator coils and evaporator fan motor (since I was getting no chilled air flow). The coils were freezing (working properly), but no excessive dirt or frost build-up. The evaporator fan motor was not running and upon testing, tested open (motor shot). I'm sourcing a new motor and will install it this evening. I've heard that the bimetal switch and defrost timer are also suspect and fail fairly frequently. Do you have any suggestions on parts I should replace with the evaporator fan motor so that I don't have to re-diagnose the same problem in the near future?
Thanks, this forum is truly a life (and $$$) saver. I sincerely appreciate the help.
Nick
  #4 (permalink)
Old 11-24-2009, 07:38 AM
Senior Expert
APP Volunteer
Default
No need to apologize, I just thought I would correct it so you do not start off in the wrong direction.
This may solve the problem. The unit relies on the proper cold air circulation to run correctly.
I does not sound like you have a defrost problem so replacing the above would just be a waste of money right now.
I think the motor will solve the problem. Now that I have said it Murphy will step in and jinx it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana side by side freezer sounds like a truck georgea Refrigerator & Freezer Repair 1 10-30-2009 07:23 PM
Amana side-by-side problem lenrosenberg Refrigerator & Freezer Repair 2 08-30-2009 04:24 PM
How to fix the freezer on side by side Amana Refrigerator Joseph Houston Refrigerator & Freezer Repair 1 07-22-2009 04:14 AM
Amana side by side freezer not cooling gunner Refrigerator & Freezer Repair 1 12-03-2007 03:30 PM
Amana Side by Side Refrigerator Freezer MFG. P1317202WE josephbowles@earthlink.ne Refrigerator & Freezer Repair 0 08-10-2007 05:38 PM
