jabez
#1 Posted : Monday, November 23, 2009 8:35:40 AM(UTC)
jabez
woke up on a saturday morning and fridge was not working,top and bottom. need help since saturday its now monday; one more thing the motor is not working on the bottom.
jabez
#2 Posted : Monday, November 23, 2009 8:39:53 AM(UTC)
jabez
stuff in fridge are going bad.
#3 Posted : Wednesday, November 25, 2009 4:06:04 AM(UTC)
Replacement parts for GE PTS22LBNARWW | AppliancePartsPros.com
Check to see if the compressor is running. Should be warm and you should be able to feel it vibrating.
If yes
Remove the cover from the evaporator coils so you can inspect them.
Check that the evaporator fan is running.
Be sure the unit has been running a couple hours before doing this. In other words do not do it just after a defrost cycle.
If they are clogged solid with ice and frost you have defrost problem.
If they only have frost in one area, usually where the freon enters the coils you are low on freon and have a leak somewhere.
If no hint of frost or cooling you are either out of freon or the compressor is toast
If you take a look through this forum you will see a huge number of GE units that use a control board with problems. Often if a fan breaks it takes the control board with it.
Fridge not working, No cooling, and no display (Refrigerator & Freezer Repair)
by thepr1nter 1/13/2021 8:22:08 AM(UTC)
fridge not working then it does (Refrigerator & Freezer Repair)
by wetweekend 11/27/2020 12:02:06 PM(UTC)
Freezer to cold fridge not working. (Refrigerator & Freezer Repair)
by Rocky80 5/22/2019 8:53:02 AM(UTC)
Freezer and Fridge not working (Refrigerator & Freezer Repair)
by davidj7479 11/9/2017 8:01:33 AM(UTC)
Amana fridge not working (Refrigerator & Freezer Repair)
by mimdou 1/6/2015 11:45:46 AM(UTC)
MAYTAG fridge not working (Refrigerator & Freezer Repair)
by Ralph Tal 12/28/2014 9:53:06 PM(UTC)
KitchenAid bottom mount fridge not working properly (Refrigerator & Freezer Repair)
by Eldub 8/21/2014 11:40:18 AM(UTC)
Fridge not working, freezer is. No frost, fan works (?) (Refrigerator & Freezer Repair)
by ornestreet 7/30/2013 4:48:12 AM(UTC)
Samsung 26cf fd freezer fine, fridge not working (Refrigerator & Freezer Repair)
by ppipowerclass 4/22/2013 3:32:57 PM(UTC)
Fridge not working and clicking (Refrigerator & Freezer Repair)
by Mbtran321 3/19/2013 5:20:08 AM(UTC)
Whirlpool Fridge not working (Refrigerator & Freezer Repair)
by rojas5 2/8/2013 8:31:59 AM(UTC)
GE Fridge not working, need help! (Refrigerator & Freezer Repair)
by robweber1 7/25/2012 4:51:04 PM(UTC)
fridge not working after power out, now hot front panel (Refrigerator & Freezer Repair)
by SueV 7/5/2012 3:16:55 PM(UTC)
Kenmore Fridge Not Working (Refrigerator & Freezer Repair)
by salenbailey 4/25/2012 7:21:30 PM(UTC)
Freezer and fridge not working..!! (Refrigerator & Freezer Repair)
by dianaha0814 3/21/2012 5:25:10 AM(UTC)
