| » Frig compressor/relay capacitor |
Model Number: 106.9557650 Brand: Kenmore Age: More than 10 years
my frig stopped cooling, when compressor tries to start, it hums then clicks and shuts off. A minute or 2 later it does the same thing. Compressor was changed out about 6-7 years ago (warranty) a Gemline all in one relay-capacitor-overload was installed at that time also.
Any thoughts? Is there a way to check a relay-capacitor? I do own a good digital ohm/volt meter. Ads By Google Related Models |
You should have the factory start/overload installed in the compressor, if not you have pool overload protection and no thermal protection.
I would order the factory start/overload device for your refrigerator and install it. If you have a meter, you can check the compressor windings for burnout.
__________________
Quote:
How would I check the compressor with the meter? I assume you are talking about checking with an Ohm meter? |
Just check the current draw when it tries to start. Locked rotor current would be around 9 amps for most modern compressors. If much higher, you probably have burn windings.
Also, I hope you unplugged the unit to save the compressor from hard start failure. If they substituted the overload device, it probably is allowing a greater than normal power surge when it tries to start. Also, ohm meter readings will only tell if the windings are blown out or shorted to the housing. Burnt windings will give normal ohm meter readings.
__________________
| Display Modes | |
| Compressor/relay/capacitor questions | sufax | Refrigerator & Freezer Repair | 9 | 02-24-2010 08:35 AM |
| Relay/Capacitor | kbl88 | Refrigerator & Freezer Repair | 0 | 09-21-2009 08:18 AM |
| Compressor not working, even after replacing relay/capacitor | Amine | Refrigerator & Freezer Repair | 4 | 05-23-2009 08:50 AM |
| How to replace retaining clip and cover over relay/capacitor of the compressor | kouklos | Refrigerator & Freezer Repair | 0 | 10-18-2007 10:27 AM |
