Discuss
Refigerator Warm,freezer Cold Only By The Coils
 in
Refrigerator & Freezer Repair
We initially had a lot of frost on the coils, even on the fan. We replaced the defrost timer and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refigerator Warm,freezer Cold Only By The Coils
  #1 (permalink)
Old 11-21-2009, 09:33 AM
Junior Member
jhbarber2001 is on a distinguished road
Default Refigerator Warm,freezer Cold Only By The Coils
Model Number: SZD20ML   Brand: Amana   Age: More than 10 years
We initially had a lot of frost on the coils, even on the fan. We replaced the defrost timer and that problem was solved. We then replaced the temperature control for the freezer and still have too little cooling in both
the refrigerator and freezer. The compressor still runs OK and we are still
cycling through defrost. Is there a limit switch somewhere that should be
replaced or could the defrost thermostat cause this problem?
Related Models
Amana SZD20ML REF - SXS/I&W
Amana SZD20MPE REF - SXS/I&W
Amana SZD20MPL REF - SXS/I&W
Amana SZD20MPW REF - SXS/I&W
Amana SZD20MW REF - SXS/I&W
Amana SZD20NE REF - SXS/I&W
Amana SZD20NL REF - SXS/I&W
Amana SZD20NPE REF - SXS/I&W
Amana SZD20NPL REF - SXS/I&W
Amana SZD20NPW REF - SXS/I&W
Amana SZD20NW REF - SXS/I&W
Amana SZD22M2L REF - SXS/I&W
Amana SZD22M2W REF - SXS/I&W
Amana SZD22MB2L REF - SXS/I&W
Amana SZD22MB2W REF - SXS/I&W
Amana SZD22MBL REF - SXS/I&W
Amana SZD22MBW REF - SXS/I&W
Amana SZD22ML REF - SXS/I&W
Amana SZD22MW REF - SXS/I&W
Amana SZD22NG REF - SXS/I&W
Amana SZD22NL REF - SXS/I&W
Amana SZD22NW REF - SXS/I&W
Amana SZD22S5E REF - SXS/I&W
Amana SZD22S5L REF - SXS/I&W
Amana SZD22S5W REF - SXS/I&W
Amana SZD23VE REF - SXS/I&W
Amana SZD23VL REF - SXS/I&W
Amana SZD23VW REF - SXS/I&W
Amana SZD25M2L REF - SXS/I&W
Amana SZD25M2W REF - SXS/I&W
Amana SZD25MB2L REF - SXS/I&W
Amana SZD25MB2W REF - SXS/I&W
Amana SZD25MBL REF - SXS/I&W
Amana SZD25MBW REF - SXS/I&W
Amana SZD25ML REF - SXS/I&W
Amana SZD25MP2L REF - SXS/I&W
Amana SZD25MP2W REF - SXS/I&W
Amana SZD25MPE REF - SXS/I&W
Amana SZD25MPL REF - SXS/I&W
Amana SZD25MPW REF - SXS/I&W
Amana SZD25MW REF - SXS/I&W
Amana SZD25N2E REF - SXS/I&W
Amana SZD25N2L REF - SXS/I&W
Amana SZD25N2W REF - SXS/I&W
Amana SZD25NE REF - SXS/I&W
Amana SZD25NL REF - SXS/I&W
Amana SZD25NW REF - SXS/I&W
Amana SZD25S5E REF - SXS/I&W
Amana SZD25S5L REF - SXS/I&W
Amana SZD25S5W REF - SXS/I&W
Amana SZD26VE REF - SXS/I&W
Amana SZD26VL REF - SXS/I&W
Amana SZD26VW REF - SXS/I&W
Amana SZD27KBL REF - SXS/I&W
Amana SZD27KBW REF - SXS/I&W
Amana SZD27KL REF - SXS/I&W
Amana SZD27KPL REF - SXS/I&W
Amana SZD27KPW REF - SXS/I&W
Amana SZD27KW REF - SXS/I&W
Amana SZD27MBL REF - SXS/I&W
Amana SZD27MBW REF - SXS/I&W
Amana SZD27ML REF - SXS/I&W
Amana SZD27MPB REF - SXS/I&W
Amana SZD27MPL REF - SXS/I&W
Amana SZD27MPW REF - SXS/I&W
Amana SZD27MW REF - SXS/I&W
Amana SZD27NE REF - SXS/I&W
Amana SZD27NL REF - SXS/I&W
Amana SZD27NW REF - SXS/I&W
Amana SZDE20K REF - SXS/I&W
Amana SZDE20K Ref - SXS/I&W
Amana SZDE20KB REF - SXS/I&W
Amana SZDE20KB Ref - SXS/I&W
Amana SZDE20KP REF - SXS/I&W
Amana SZDE20KP Ref - SXS/I&W
Amana SZDE20MBL REF - SXS/I&W
Amana SZDE20MBW REF - SXS/I&W
Amana SZDE20ML REF - SXS/I&W
Amana SZDE20MPE REF - SXS/I&W
Amana SZDE20MPL REF - SXS/I&W
Amana SZDE20MPW REF - SXS/I&W
Amana SZDE20MW REF - SXS/I&W
Amana SZDE25K REF - SXS/I&W
Amana SZDE25KB REF - SXS/I&W
  #2 (permalink)
Old 11-23-2009, 03:30 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here are the parts
Replacement parts for AMANA SZD20ML | AppliancePartsPros.com
still have too little cooling in both the refrigerator and freezer. The compressor still runs OK and we are still
Check to be sure the evaporator fan is running.
Also the compressor fan and that the condenser coils are clean.
Remove the evaporator coil cover and check the coils.
If heavily iced/frosted over then you still have a defrost problem.
Check the defrost thermostat and the defrost heater.
If the compressor is running and there is no cooling at the evaporator coils. then the compressor could be toast or you may be out of freon.
If you only have frost on one section of the coils (usually where the freon enters the coils), you could be low on freon.
Either of the above is usually the end of the unit as finding a freon leak,repairing it and recharging the unit is fairly expensive.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fridge warm freezer cold coils icing up ron f Refrigerator & Freezer Repair 1 10-19-2009 04:53 PM
coils freezing up in freezer and frig temps warm dhofer Refrigerator & Freezer Repair 3 06-02-2009 06:01 PM
freezer works but refigerator is to warm te4mundt Refrigerator & Freezer Repair 1 02-09-2009 06:35 AM
Freezer warm/Refigerator warmer hody Refrigerator & Freezer Repair 8 03-29-2008 11:16 AM
refigerator is warming up and freezer is too warm crazeecook2 Refrigerator & Freezer Repair 1 08-17-2007 03:53 PM
