Discuss
Water dispenser acting goofy
 in
Refrigerator & Freezer Repair
I purchased a Kenmore double door (w/ice maker and water dispenser) refrigerator in 2004. Lately, it has been making
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water dispenser acting goofy
  #1 (permalink)
Old 03-03-2008, 03:35 PM
BobW BobW is offline
Junior Member
BobW is on a distinguished road
Default Water dispenser acting goofy
Brand: Kenmore   Age: 1 - 5 years
refrigerator in 2004. Lately, it has been making a da, da, da, da, da, noise,
off (3 or 4 times per day)and on, usually late at night or early a.m
hours and for only a few seconds (up to 30)each time. The noise coincides
with the water dispenser dispersing water irregularly. The noise stops
and the water returns to normal when I open the refrigerator side
door, not the freezer side. My filter is about 4 months old. Could this be
a filter problem causing this?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-04-2008, 03:00 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Did you remove a couple of gallons of water (through the dispenser) after you replaced the filter last time? Sounds like there is an air inside the system.
For more accurate advise I need the complete model number of the fridge.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-04-2008, 03:19 PM
Junior Member
Gene:
Thank you for your reply. I removed only 5 or 6 full glasses of water before I started using it. Model number is Kenmore 10644109300.
  #4 (permalink)
Old 03-04-2008, 03:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Bob,
Remove more water and check the water tank (on the bottom in the fresh food compartment) for any small crack.
__________________
  #5 (permalink)
Old 03-07-2008, 02:19 PM
Junior Member
Default It worked!!!
Thanks Gene for all of your help. I removed more water. It seems to be working fine now.
  #6 (permalink)
Old 03-07-2008, 04:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice & Water Dispenser In-Op GE mvosevich Refrigerator & Freezer Repair 0 01-21-2008 06:51 PM
water actuator on water dispenser sixkings Refrigerator & Freezer Repair 1 01-07-2008 10:33 AM
Thermador Acting Strange chrisw Oven Repair (including Ranges and Cooktops) 8 01-07-2008 08:43 AM
water/ice dispenser schumske Refrigerator & Freezer Repair 2 10-10-2007 04:26 PM
ice dispenser working...water dispenser not rishuk Refrigerator & Freezer Repair 0 09-25-2007 04:03 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
