My fridge is 2 weeks past the one year warranty, ouch. Anyway, last night, we had water on the floor that had run down the door from the ice/water dispenser tray. On further investigation, the issue is caused by the fact that every time we dispense water, the ice cube maker gets sprayed with water.
I'm not sure if it is enough to fill the tray each time, but it is enough that it overflows the tray and then leaks down to the bin and out the ice dispenser opening. This happens if the icemaker is in the on or off position.
Any help much apreciated.
thanks
wood9663
