Discuss
refrigerator stops running
 in
Refrigerator & Freezer Repair
The fridge stops working, if I tap on the top front inside of the refrigeator it starts and runs for
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » refrigerator stops running
  #1 (permalink)
Old 11-17-2009, 04:28 PM
Junior Member
tbollm1 is on a distinguished road
Default refrigerator stops running
Model Number: ED25PQXFN02   Brand: Whirlpool   Age: 5 - 10 years
The fridge stops working, if I tap on the top front inside of the refrigeator it starts and runs for a while and will cool. I have replaced the defrost timer and the problem still is there.
Ads By Google
Related Models
Whirlpool ED25PQXFN02
Whirlpool ED25PQXFW00
Whirlpool ED25PQXFW01
Whirlpool ED25PQXFW02
Whirlpool ED25PQXYN00
Whirlpool ED25PQXYN01
Whirlpool ED25PQXYW00
Whirlpool ED25PQXYW01
Whirlpool ED25PSQDN00
Whirlpool ED25PSQDN01
Whirlpool ED25PSQDW00
Whirlpool ED25PSQDW01
Whirlpool ED25PSXDN00
Whirlpool ED25PSXDN01
Whirlpool ED25PSXDN02
Whirlpool ED25PSXDW00
Whirlpool ED25PSXDW01
Whirlpool ED25PSXDW02
Whirlpool ED25PSXRWR0
Whirlpool ED25PSXRWR1
Whirlpool ED25PWXAN00
Whirlpool ED25PWXAN01
Whirlpool ED25PWXAN02
Whirlpool ED25PWXAW00
Whirlpool ED25PWXAW01
Whirlpool ED25PWXAW02
Whirlpool ED25PWXBN00
Whirlpool ED25PWXBN01
Whirlpool ED25PWXBW00
Whirlpool ED25PWXBW01
Whirlpool ED25PWXDN00
Whirlpool ED25PWXDN01
Whirlpool ED25PWXDW00
Whirlpool ED25PWXDW01
Whirlpool ED25PWXTF00
Whirlpool ED25PWXTG00
Whirlpool ED25PWXTM00
Whirlpool ED25PWXTN00
Whirlpool ED25PWXTW00
Whirlpool ED25PWXWN10
Whirlpool ED25PWXWW10
Whirlpool ED25PWXXN00
Whirlpool ED25PWXXN01
Whirlpool ED25PWXXW00
Whirlpool ED25PWXXW01
Whirlpool ED25QFXHB00
Whirlpool ED25QFXHB01
Whirlpool ED25QFXHB02
Whirlpool ED25QFXHN00
Whirlpool ED25QFXHN01
Whirlpool ED25QFXHN02
Whirlpool ED25QFXHT00
Whirlpool ED25QFXHT01
Whirlpool ED25QFXHT02
Whirlpool ED25QFXHW00
Whirlpool ED25QFXHW01
Whirlpool ED25QFXHW02
Whirlpool ED25RFXFB00
Whirlpool ED25RFXFB01
Whirlpool ED25RFXFB02
Whirlpool ED25RFXFB03
Whirlpool ED25RFXFN00
Whirlpool ED25RFXFN01
Whirlpool ED25RFXFN02
Whirlpool ED25RFXFN03
Whirlpool ED25RFXFW00
Whirlpool ED25RFXFW01
Whirlpool ED25RFXFW02
Whirlpool ED25RFXFW03
Whirlpool ED25RQXFN00
Whirlpool ED25RQXFN01
Whirlpool ED25RQXFN02
Whirlpool ED25RQXFW00
Whirlpool ED25RQXFW01
Whirlpool ED25RQXFW02
Whirlpool ED25RQXWW00
Whirlpool ED25RQXWW02
Whirlpool ED25RQXXW00
Whirlpool ED25RQXYW00
Whirlpool ED25RQXYW01
Whirlpool ED25RQXYW02
Whirlpool ED25SM1LWR0
Whirlpool ED25SM1LWR1
Whirlpool ED25SMXLWR0
Whirlpool ED25SMXLWR1
Whirlpool ED25SMXLWR2
Whirlpool ED25SMXRWR0
Whirlpool ED25SMXRWR2
Whirlpool ED25TEXHN00
Whirlpool ED25TEXHN01
Whirlpool ED25TEXHN02
Whirlpool ED25TEXHN03
Whirlpool ED25TEXHT02
Whirlpool ED25TEXHT03
Whirlpool ED25TEXHW00
Whirlpool ED25TEXHW01
Whirlpool ED25TEXHW02
Whirlpool ED25TEXHW03
Whirlpool ED25TQXEN00
Whirlpool ED25TQXEN01
Whirlpool ED25TQXEW00
Whirlpool ED25TQXEW01
Whirlpool ED25TQXFN00
Whirlpool ED25TQXFN01
Whirlpool ED25TQXFN02
Whirlpool ED25TQXFN03
Whirlpool ED25TQXFW00
Whirlpool ED25TQXFW01
Whirlpool ED25TQXFW02
Whirlpool ED25TQXFW03
Whirlpool ED25TQXGN00
Whirlpool ED25TQXGW00
Whirlpool ED25TWXDN00
Whirlpool ED25TWXDN01
Whirlpool ED25TWXDW00
Whirlpool ED25TWXDW01
Whirlpool ED25UEXHT00
Whirlpool ED25UEXHT01
Whirlpool ED25UEXHW00
Whirlpool ED25UEXHW01
  #2 (permalink)
Old 11-18-2009, 07:04 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL ED25PQXFN02 | AppliancePartsPros.com
If by "stops working" you mean that the compressor will not start, this is not a defrost problem. If you had a defrost problem the compressor would probably run all the time. The unit would try to cool down but never be able to achieve it's set point since the air is not cooled efficiently.
My guess would be that your thermostat contacts are sticking open.
__________________
  #3 (permalink)
Old 11-18-2009, 03:36 PM
Junior Member
Default
Yes, the compressor stops running and will not start unless I tap on the inside top of the fridge. I was told to replace the defrost timer (told it was probably stuck on defrost which will keep the compressor from starting). So,,,, should I replace the cold control?
  #4 (permalink)
Old 11-18-2009, 07:00 PM
Senior Expert
APP Volunteer
Default
That is what I would do as it does not sound like a defrost problem and you have already replaced the defrost timer.
To double check rotate the timer to just before a defrost cycle.
Mark a spot the defrost timer cam and also on the frame.
The marks will tell you if it is advancing.
Let it go into defrost.
Check it in half an hour it should be out of defrost by then.
If the cam continues to rotate then odds are very high that the timer is OK.
__________________
  #5 (permalink)
Old 12-27-2009, 02:55 PM
Junior Member
markjenna is on a distinguished road
Default
I also have the same problem, but mine only happens when it gets cold out. I have the frig in the garage as a second one. During the summer all is good. Once it gets cold out everything defrost. Once the temp gets below like 40. If I turn the heat on in the garage it freezes again. Any thoughts?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE fridge never stops running redouse Refrigerator & Freezer Repair 8 12-26-2009 06:28 PM
Motor stops running Jimbo66 Washer Repair 1 12-08-2009 04:24 PM
dryer stops running RobinAlice Dryer Repair 3 09-21-2009 01:14 PM
Dryer stops running den123 Dryer Repair 1 11-10-2008 05:16 AM
fridge never stops running seahawk Refrigerator & Freezer Repair 1 06-19-2008 08:19 AM
