2 Pages12>
wiskyhome
#1 Posted : Tuesday, November 17, 2009 8:13:08 AM(UTC)
wiskyhome
Our fridge is 4 yrs old and the ice maker quit. I tried a hair dryer on the water tube in freezer with no luck.We still get water out of the water dispencer but the pressure seems a little weak to me. I pulled out the fridge and seem to have good pressure coming in from the pipes when i turn the valve on.I pulled the (4389177) filter valve and disconnected the tubes coming from the filter and there was a little water.We just put a new water filter in about 2 weeks ago. I am thinking that either the Filter valve assy is bad or the part# 6266653 module assy inside the freezer is bad. If the filter is bad is it just a matter if disconnecting the tubes and plugs? or more to it.It seems like it would be about a 10-20 minute job.Thanks for your help in advance.
#2 Posted : Tuesday, November 17, 2009 10:39:47 AM(UTC)
Make sure the ice maker "on-off" switch on the right side is in "on" position. Open the freezer door, press in the emitter flapper door (on the left side) to unblock the optics beam and view the diagnostics "status" LED on the right side. Post the results.
wiskyhome
#3 Posted : Tuesday, November 17, 2009 10:53:17 AM(UTC)
wiskyhome
I pushed in the flap opened the flap by the ice maker so the light in the freezer went off,and the flap on the left side of the fridge and the red led light pulsed/flashed on for a second and off for a second for the 20-30 seconds i monitored it
wiskyhome
#4 Posted : Tuesday, November 17, 2009 12:09:08 PM(UTC)
wiskyhome
I went back an hour later closed the flap on the lfet and the red light next to the on/off switch just stayed on
#5 Posted : Wednesday, November 18, 2009 10:39:05 AM(UTC)
According to your replies the optics are not stable and very likely are bad.
Remove the ice maker and check for 120VAC between the black and white wires at the plug.
wiskyhome
#6 Posted : Wednesday, November 18, 2009 11:18:41 AM(UTC)
wiskyhome
Is that easy to get out. Just the bolts inside the freezer compartment?
#7 Posted : Wednesday, November 18, 2009 11:39:57 AM(UTC)
Remove the wire shield screw from the bottom of the ice maker.
From the rear of the ice maker, lift the top of the wire shield slightly and pull it
back to release it from the ice maker. Press up on the two retaining clips (one on each side) at the bottom of the ice maker tracks with a fingernail of each hand, pull the ice maker forward, and remove it.
Unplug the wiring harness connector from the ice maker.
wiskyhome
#8 Posted : Wednesday, November 18, 2009 11:43:09 AM(UTC)
wiskyhome
Thank you i will try it and post the results
wiskyhome
#9 Posted : Sunday, December 13, 2009 9:46:46 AM(UTC)
wiskyhome
I pulled the ice maker and tested the wires 3 times and each time the reading was 108.8. Sorry for the delayed reply i was out of town for a bit.
#10 Posted : Sunday, December 13, 2009 4:55:05 PM(UTC)
Do the following test:
Make sure the "on-off" switch on the right side is "on". Remove the ice maker head cover (do not unplug the ice maker). Insert the voltmeter test probes in the "N" & "L" ice maker test points. Make sure the test probes are at least 1/2" in. Push in and hold the door light switch and wait at least 5 seconds before the voltage test. Post the results.
Ice Maker Not Making Ice At All Times (Refrigerator & Freezer Repair)
by danrclem 6/11/2023 6:52:52 PM(UTC)
Whirlpool WRF535SMBM00 Ice maker not making ice (Refrigerator & Freezer Repair)
by Derek Halter 3/7/2023 12:03:25 PM(UTC)
LG Refrigerator LFX21960ST Ice maker not making ice (Refrigerator & Freezer Repair)
by tfmc369 9/19/2022 9:02:45 AM(UTC)
Under Counter Ice Maker not making ice (Refrigerator & Freezer Repair)
by ling_appliance 3/13/2022 5:55:41 AM(UTC)
FRS26KF6EM4 Ice Maker not making ice (Refrigerator & Freezer Repair)
by johnhurst 9/3/2021 10:14:18 AM(UTC)
Maytag ice maker not making ice, I don’t know what else to try... (Refrigerator & Freezer Repair)
by Karnsky 12/11/2020 5:09:39 PM(UTC)
Whirlpool Ice Maker Not Making Ice (Refrigerator & Freezer Repair)
by hanginghelmet 5/8/2016 2:24:52 PM(UTC)
Whirlpool Ice Maker not making ice (Refrigerator & Freezer Repair)
by turbotribes 8/1/2015 9:44:31 AM(UTC)
by kidmims 7/25/2015 9:41:54 AM(UTC)
Ice Maker not making Ice. (Refrigerator & Freezer Repair)
by atticus1 6/11/2015 5:28:24 PM(UTC)
by gaff 11/13/2013 7:29:05 PM(UTC)
Ice maker Not making ice (Refrigerator & Freezer Repair)
by chavisfamily1234 11/2/2012 8:52:20 PM(UTC)
by cgoodwin 8/2/2012 11:07:55 AM(UTC)
by Guido 6/22/2012 9:40:34 AM(UTC)
Kenmore Ice Maker not making Ice (Refrigerator & Freezer Repair)
by ghauptman 5/25/2012 1:47:12 PM(UTC)
2 Pages12>
